Generally on a four stroke you'll want to use a Keihin PE type carb, the '85 250r came with a 34mm PE. After doing the mods I had to upgrade the carb because it was a bear to start with the little carb. I had the stock carb from my '85 R and I was going to rejet and run that (it think that would have worked OK) carb but when I called Duncan Racing they talked me into getting a new 38mm PE with a twist throttle and a jet kit. I have to say I don't regret it a bit, the machine starts better than most stock 350X's, will run with a stock 250r in a drag race, and will idle all day long without a hiccup. It took some time to get the jetting down 100% but now it is really a joy to use that trike. You can spend a small fortune on some crazy trailprotrailprotrailprotrailprotrailpro Edelbrock carb but for my money get a PE and you'll be happy you did. As for an accelerator pump, when you hit the gas it shoots a small load of fuel in the carb throat (similar to a water pistol squirt) to be sure there is no lean spot. The PE has no suck pump but mine is right there when I hit the gas.
John
1985 Eddie Sanders ATC330r
1986 Monstecate
1984 ATC70 (awaiting 125cc transplant)
1984 ATC125M
1986 GSXR 750 - Keepin' it old school!
1999 Arctic Cat 500 4x4 plow machine
1999 Arctic Cat Thundercat 1000 (lake lizard)
1996 Arctic Cat Jag 440 L/C (ditch banger)
