Thread: Tire + wheel questions
    May 2005
    Dorset United Kingdom
    1,408
    Ok....... Im in the process of choosing tires for my Z and im looking around at the selections there are, Im looking at the sizes and it seems there is more choice for a 9" wheel than there is for an 8"
    So I go and measure my wheel and it comes up as 9" exactly Outer lip to outer lip, but the tire that is on the wheel is marked 22 x 11 x 8! WTF!
    Am I measuring the wrong place on the wheel?
    Will
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Ontario, CANADA
    4,538
    I have found this helpful Will, do a nice search and wola!
    LINK!
    I know when I ordered tires they were 20-11-9's. So I know for a fact I got 9's. Hope this helps!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Rittman, Ohio
    6,276
    Its not measured at the outer lip, but where the bead seats. That is the bead measurement.
    There are a lot more choices in 9" tires than in 8", but you have to go to a different rim. You might look at some tire/rim combos from rockymountainATV. Z bolt pattern is 4/100, same as Blaster which also came with 8" rims.
    May 2005
    1,408
    Ok, Thanks Tim and Kintore........ ill see what 8 inch tires I can get
    holeshots, klaws, holeshot new sx, turf tamers,shredders,mud sharks,dirt dogs,fast trekker,x-driv, theres lots of choices! or switch your rims to a 86 9" rim and it opens your slection or get banshee hubs and rims and run 10" tires.good luck!!! been there done it! lol
