Results 1 to 9 of 9
Thread: Tecate axle?
    Apr 2003
    Dodge, Nebraska
    168
    Tecate axle?
    Anyone know for sure if a Tecate-4 axle will work in an 86-87 Tecate-3???
    It ain't about the money, or even being #1, you gotta know when it's all over you did the best you could of done! And knowing that it's in you and you never let it out, is worse then blowin' any engine or any wreck you'll ever have!
    _________________________________
    84 Tecate RED with a 310 Big bore!
    84 Tecate Red
    84 Tecate Green, in pieces(was a parts bike, not anymore!! )
    85 TECATE--NICE!
    85 350x needs a little tlc
    86 350x
    86 TRI-Z
    Sep 2005
    MICHIGAN
    2,027
    There is a guy on the board with a 400EX axle in one.
    86 T3
    84 T3
    86 KX250
    Dec 2003
    australia
    838
    What, a 400ex axle in a 86/87 Tecate three wheeler?
    As for the first question, I emailed Dura blue recently enquiring about 86/7 T3 axles and they told me that they had Tecate4 axles, so I asked them if they fit a
    Tecate three wheeler and the answer came back as No. Which made me wonder why they bothered to tell me about the T4 axle??
    As for the 400ex, any one know how to fit one of those up to a T3?
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
    Jul 2003
    indiana
    892
    I have read that it will not bolt in. But I have never looked at one to see if there are any differeces in the carriers. If they are close to bolting, you could always mad a T4 carrier to work. I would get a cheap one off ebay to mess with before you spend bucks on a good axle and carrier.
    Oct 2005
    saratoga, ny
    2,819
    i know that miltech uses either 400ex or 250r raer carriers when they make a new swinger for the tecate. i am getting ready to order myself one with a 400ex carrier, it gives you more choices for axles that way. maybe that is what the guy was talking about.
    Sep 2005
    MICHIGAN
    2,027
    400EX axle
    Look at the response i got when I asked the same ? 400EX axle + Tecate carrier.
    http://www.3wheelerworldforums.com/s...ght=400ex+axle
    86 T3
    84 T3
    86 KX250
    Dec 2003
    australia
    838
    Well it looks as if the tecate3-4 axle swap is not going to be a goer, I was thinking of putting a Banshee "swinger" type bearing carrier on the back of my Tecate.
    Banshees are quite common and the yamaha rear caliper looks very similar to my Tecate one. Putting a different model swinger carrier on a swing arm designed for a swinger carrier shouldn't be too taxing on the old brain.
    May 2002
    Texas
    2,670
    The Tecate-4's carrier is eccentric type, like a Honda 250R. All Tecate 3-Wheeler carriers are a swing type, like a Banshee. So no switching Tecate 3-Wheeler and 4-Wheeler carriers.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Dec 2003
    australia
    838
    Quote Originally Posted by Jeb
    I was talking about putting a banshee carrier on to a tecate swing arm.
