Results 1 to 11 of 11
Thread: yamma 225 starting/hose problems
    Feb 2006
    new hampshire
    4
    okay
    got a yamma 225 for free a while back, never touched it until yesterday.
    the kid i got it off of said nothing wrong with it just put carb back on and your good to go
    well i put the carb back on yesterday and pulled and pulled nothing
    first off theres 3 hoses out of the carb, the main gas line, another hose nipple abover maine gas line and then the bowl overflow line
    when i turn the gas on the bowl overflow will NOT stop flowing, gas goes in as fast as it goes out and i have no clue how to stop it.
    i capped it off, but then gas was comig out both sides of the carb so thats a no go. any clue as to how to stop or fix the overflow problem there?
    also the 2nd hose nipple i read is another overflow hose and runs up along gas tank/frame. so im assuming it goes to noghtin, is this correct?
    the first day i tried playing with it i did get the motor to pop but thats it, nothing has happened since then.
    i have poured gas into the cylinder a couple different times and nothing.
    the plug is getting spark but i havent checked the gap yet, also plug in it is a 7ae, is this the right plug?
    it was an electric start but i guess all the lines are disconnected, i do plan on taking them all out and keeping it just a pull start.
    i cant quite figure out why theres no spark, unless its getting too much or not enuf gas but like i said its weird cuz ill put gas in cylinder and pull it and nothing will happen.
    Oct 2005
    Pennsylvania
    863
    Float in the carb is stuck open--"REFRESH it"
    Pop the plug out and make sure there is a spark at theend of the plug--If your carb is overflowing --the plug MUST be fouled
    Get a wiring diagram and fix the electric starter---It will be well worth the effort
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Oct 2005
    Pennsylvania
    863
    Sorry--My manners again---
    To the boards
    Yes the second hose dissapears into the frame--Its the Bowl "VENT"
    Feb 2006
    new hampshire
    4
    ok ill take out the carb and "refresh it" whatever that means lol (ill figure it out)
    yes the plug is getting spark, i have had it out and on the block, pulled it and spark
    to get it refixed means ill have to run new wires off the battery cuz the old ones are all corroded and stuff, and theres no push button or anyting so either ill have to yank one off another wheeler, or rig it up, but if you say its worth it ill do that this spring.
    Oct 2005
    Pennsylvania
    863
    Refresh-----Not quite a rebuild---More like......Two cans of Carb cleaner..an old Toothbrush--And a service manual-------Slowly dissasemble and look at the float
    (Its a good idea to get a big towel on your work table and take it apart above the towel --there are parts that CAN fall out un noticed)----
    As you dissasemble you will understand what the float does and why it doesnt stop the fuel flow-----
    Feb 2006
    new hampshire
    4
    okay so carbs out, took off bowl and theres nothing at all that can be taken off or anythning, so im assumign im missing parts, is there any pics of this carb taken apart?
    Oct 2005
    Pennsylvania
    863
    Bike Bandit .com------find your bbike and go thru the parts diagrams---
    If you need them I can scan the pages from the Service manual--
    Oct 2005
    Pennsylvania
    863
    Feb 2006
    new hampshire
    4
    thx that does help alot, i also forgot to mention the reason that all i had to do was put the carb on and im good to go, was cuz he took it off to clean it and apparently didnt put it back together right.
    besides that the motor should turn over by putting gas down the cylinder. im trying that without the carb on and still nothing. now it has been sitting for a long time and stuff and it is cold up here (currently its snowing and like 15 degrees or so) maybe itll just take alot of pulling to get it started?
    also since it was electric start....exactly where is the starter so i can just hook a battery up there and try it like that?
    ill be looking for a starter now anyways and probiubly find it
    Oct 2005
    Pennsylvania
    863
    The gas in the cylinder really cant do anything with the wide open hole where the carb should be-----Are the parts in the carb at all?----as for the starter---
    http://www.files.3wheelerworld.com/W...5DXKDXLDXN.jpg Our fearless leaders have been kind enough to provide us with this stuff --so use em'
    Jun 2003
    South of Rochester, NY
    3,470
    Quote Originally Posted by Unclediezel
    There are Yamaha parts schematics on the Homepage under Service Manuals or such....
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
