Im tearing the top end apart but cant get the cam chain loosened to get it off. took the tensioner off the bottom of the motor. Didnt make a difference. Do I take the cam sprocket off or what. If so how do I do that?
200s
110
KLT160
Yes take the bolts out of the cam sprocket, then you can pull the cam out, the Sprocket will drop down, and pull the head, dont let the chain+sprocket fall Down intpo the bottem end, its a PITA to get out again.Originally Posted by dooner17
1985 Tri-Z-
Originally Posted by mywifeknowseverything
Ok, its all apart now. I'm replacing the rings because the bike smokes. The piston says honda on it but I dont know if it's stock or not. How do I tell what rings to buy. Can I just assume that its stock with the Honda piston?
200s
110
KLT160
Ok I think it said STD. I'll go take a look.
200s
110
KLT160
it doesnt say standard, it has HONDA on one side and .2 and a number like 947 on the other side.?
200s
110
KLT160
Look on the rings, if you take them off, on the top side of them near the ring end gap should be a number, if its standard Bore and rings it will say STD or just a T, if its oversized it will normally have a number like.50 or something, also on the top of the piston, you will have to take some scotch pads or wire wheel to see the stamp in the top if its oversized.
1985 Tri-Z-
here is what my stock pistion looks like. i was thinking that a new piston would have std on it. my original just says IN on the top, Honda on the one side, and Z943 on the other side.
Someone has done the rings on your 110 before wheelipop, thats the Replacement oil ring, the stocker is a 1 pice unit....just to let you know![]()
1985 Tri-Z-
ok I think mine says, z 943 too, how do i get the rings off to check them?
200s
110
KLT160
oh yeah, I just want to find out if it's standard or not so I can order the rings.
200s
110
KLT160
gota grab the 1 ring endgap on the top, pull it up and kinda twist the piston off it.....hard to explain...if you havent put rings on before i suggest you order 2 sets so your not Cursin when you break your first one.Originally Posted by dooner17
1985 Tri-Z-
Ok, so your saying I need to remove the circlips and take the piston off
200s
110
KLT160
Get a manual. They explain what to do, that is what they are for. If you have to, take the piston to the dealer and have them measure it.
