Results 1 to 13 of 13
Thread: 350x headlight on a 200x????
    crd00's Avatar
    crd00 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2006
    somewhere over the rainbow
    323
    Exclamation 350x headlight on a 200x????
    Will a 350x headlight work on a 200x?What would I have to do to make it work?
    I'm sure it will, it works great on the SX and the R. You simply have to wire it up in parallel to the leads on the 200X headlight. Different width triple clamps require flipping the rubber straps around, thats all...
    You need a regulator in there though or you will pop those $22.00 headlight bulbs, you should be able to pick one up from dennis kirk for 10 bucks...
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Is there any light differance than the 200X single light?
    Quote Originally Posted by BLAZERONE22
    Hey Dave, whats up. Whats different about the 200X regulator versus the other ATC's?? I thought they all regulated the voltage to a voltage any headlight could be used.
    I don't remeber the 200x having a regulator. its seemed on one of my bikes I had wired a 350x light up, and popped both bulbs, I'll be dipped if I can remember which one, but I'm pretty sure it was the 200x...
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Yep it was this one, see the blown bulb...
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Us
    727
    You know i don't like the early 's red motors, but for some reason that red on the 200x motor looks awesome. Sorry to steal the thread, just needed to get that off my chest
    Maybe it had a bad regulator?? Anything with a lighting coil has to have a regulator doesn't it???
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Anything with a lighting coil does not have to have a regulator. 83-85 200x did not have a regulator. It depended on the load of the headlight bulb to limit the voltage. That is why on that trike if your headlight bulb burned out, your tail light would get blown. You can use a 350X regulator to protect the headlights. The reason the 350X headlights are at risk is that when you power on the two lights in parallel, one of them will come on faster than the other. That may cause it to blow, and then the other light by itself can blow.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    If they were wired in series I can see a problem but in parallel how can one light work different then the other? it's parallel....
    Also, I've been running these on my 2 SX's without any problems for about 2 years. Should I be using 350X regulators?? They seem to work fine with the SX voltage setup yet in stock form the SX runs a single light like the 200X.
    ATCnut is the guy to ask, he can make a cell phone out of a banana. SERIOUSLY....
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Nov 2002
    Auburn Washington
    799
    The 350X bulbs are in parallel. The way a light bulb works is it has to heat up to make light. Untill it heats up, it draws more current. The two bulbs do not heat up at exactly the same rate (we are talking about fractions of a second difference here) The stock 200x setup depends on the 60 watt headlight bulb to limit the voltage of the stator. When one 35 watt 350x bulb heats up faster than the other one, it may not provide enough load to the 200x stator, the voltage will spike, and the bulb will blow. Then you are left with just the other 35 Watt bulb, and it may blow too. Its cheap insurance to add a 350X regulator to the trike to protect the expensive bulbs.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    85 350X (the best)
