Results 1 to 8 of 8
Thread: Motor, shipping ?
    YAMAHA_Jim's Avatar
    YAMAHA_Jim is offline 4 Motos, 3 Wheels, 2 Classes, 1st Place Arm chair racerJust too addicted
    Apr 2003
    Rock Hill,NY
    1,000
    Motor, shipping ?
    I've never sent a motor out before.Is it best to box it up in a wooden crate or package it up tight in a cardboard box? Personally I feel better knowing its safe in a sealed wooden crate and not getting tossed around in a cardboard box This would be a blaster motor. Just wondering whats the best way to go, thanx
    springville, PA
    6,185
    Try not to ship it in cardboard. I have had 3 engines now get the sidecases cracked due to inpropper shiping practices (i.e. Cardboard boxes.)
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Aug 2002
    NY
    2,652
    hey jim
    if you are shipping throgh the UPS box it up in a wooden box. i asked the local UPS place,they said it is better that way. and cheaper then a rubbermaid tote. i have shipped numerous motors in a rubbernmaid tote. i grab then on sale at the local walmart. pack the helll outta them and havent had any problems. just make sure to put a few layers of cardboard on the bottom of the motor. if they drop it down hard, the oil drain could break the case. the cardboard will cushion the motor. feel free to go the extra mile it pays in the end. i just recieved my 350x motor from UPS. the wooden box was all busted up. but he put a lot of cardboard on the bottom. it saved the motor. the sprocket cover and decompression cable bracket got bent. but otherwise no to much to complain about lol how you feeling by the way??? take it slow later mike
    danteross77's Avatar
    danteross77 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2005
    Texas
    339
    I have never shipped through ups, because they are too expensive. I have shipped several motors through Fed Ex Ground and they have all arrived well, I used a heavy duty double layered cardboard box and then I took atleast 5 layers of cardboard on all sides of the motor, then packed every space with packaging paper. Seal the box and put metal shipping bands around the box so it is easy to carry(Hint: if it is easy to carry it will not be slamed down so hard)
    Jul 2004
    Mud hill. close to water !
    3,658
    A rubermaid container is a good idea.. how heavy is it ?
    Wedge it in there with cardboard and zip tie the lid on .. ( drill holes and use multiple zip ties !! )
    Write the address info on the thing with a black marker or liquid paper if it's a black r-maid.. labels tend to peel of those easily.
    Currently :
    YAMAHA_Jim's Avatar
    Apr 2003
    Rock Hill,NY
    1,000
    Thanks guys,
    I'm guessing the motor weighs 60-70 lbs. I didnt check into shipping costs yet.If its that much I'll just drive it there and pick it up when its ready.Only about 6 hrs one way.
    Jul 2004
    3,658
    If it's that close .. it may not bee too much to ship. ( Consider gas cost and go from there )
    Currently :
    Dec 2003
    SE PA
    683
    Shouldn't cost you too much to ship it that close. I've shipped several motors thru UPS, had a few shipped to me and no problems yet.
    I usually use a rubbermaid tote or a heavy carboard box. Survival depends more on the packaged part inside the container, and the taping of the container, not so much the container itself. I pack the engine in foam all around. I use that soft forming foam with the silver plastic wrapping (it comes in radiator boxes, and whenever we replace radiators at the shop I steal the foam). You can also wrap it up in tons of bubble wrap, or use the white styrofoam that is commonly used in packing appliances and electronics. Take the spark plug out of the motor (it will poke thru the package if you don't) and plug the hole. When taping up the package, be sure to use the fiberglass reinforced strapping tape and wrap it tightly, all the way around, as if it were a band. I have a banding machine and often use plastic bands as well, but the fiberglass tape works well by itself if you use enough.
    A wooden crate will work too, but you still have to use tons of packing material to keep it safe. The monkeys that work in the shipping terminals don't care about your motor. They toss and throw stuff all around. The package will get inverted, rolled, laid sideways, and anything else they can do to it. You have to keep this in mind when packaging. And yes, it's true, if the package is easier to lift and handle, it's less likely to get rolled, drug, or slammed.
    Sorry to be so long-winded, but if you want it to be safe, do it right! And make sure the package is insured for the full value of what's inside! Good luck!
    [FONT="Palatino Linotype"]~My Rides (to name a few) ~
    1986 ATC250R, 1985 ATC350X
    1985 ATC250R Missile (90% done)
    1983 ATC185S
    1999 TRX416EX
    2003 Honda CBR600RR
    1990 Yamaha Zuma
    1985 XR80 w/100 motor
    1967 Honda CB77, '65 CL77
    1962 Puch 250 SGS
    1984 XR350R (owned since I was a kid)
    1972 Suzuki T350 Rebel, '73 T500 Titan
    1964 BSA A65 (needs restored)
    1968 BMW R60/2 mint original bike
    1976 Kawasaki KH500 triple
    Anybody have parts to trade for the above models?
