Results 1 to 7 of 7
Thread: big red to sx
    scotland
    87
    big red to sx
    what would it take to change a big red to a 250 sx what bits ? the reason i am thinking of this i have a big red and you cant get 250sx in UK and mabay get the bits over from the US if not to costlay . what do you guys think
    crd00's Avatar
    crd00 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2006
    somewhere over the rainbow
    323
    Thumbs up
    If it was me I would just buy a 250sx off of ebay because it would a lot cheaper than buying the parts for your big red
    WWW.FASTRACKZ.COM!! Totally dedicated to Atv's/MX/Sleds. Go take a look at the photoalbum and drop into the forum and say hello!
    Jul 2004
    Mud hill. close to water !
    3,658
    The front forks should be easy enough to bolt up.. but i'd go with 200X front forks if i was you.. gives you disk brakes !!! the SX has drum.
    The swingarm assembly i would leave alone.. just swap the rims for 22's instead of the red's 25's.
    The plastics might be a chore to bolt up.. that's gonna need some work.. but the rest is pretty much the same.
    Currently :
    scotland
    87
    Buying a sx of ebay is not the prob its the shipping over to Scotland UK $1300
    Is the gas tank the same as the sx and what tripe trees would i use as the sx looks wider than the 200x . and are sx fenders + seat hard to get? i have only
    ever seen a pic of a sx as you do not get them over in the UK so its hard to relate
    to one
    Jason T's Avatar
    Jason T is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    UK
    341
    There is this one I know about......
    http://www.3wheelerworldforums.com/s...ad.php?t=38932
    Your next challege is to try and pry it out of my dads hands, I think he will be buried with that bike!!!
    We considered converting an ES, but it really is a lot of work. The frame is very different to fit the SX plastics.
    I'm fairly sure the tank is different, and the plastics and seat aren't that easy to come by
    We got ours from Germany, they come up every now and then on German ebay, that might be your best bet
    Jason T
    scotland
    87
    Hi Jason thanks for that ,this could be a project for next year if i can get the bits, or keep a look on the German ebay, for a sx , at the mo i am trying to get the rest
    of the bits for my 86 250r so i can get it looking good .
    Mar 2005
    overton, PA
    5,257
    the major diffrences are frame swingarm are totaly diffrent, the plastics and tank are diffrent, the rear diff gears are diffrent to pull the taller 25 inch tires, the transmission gears are also diffrent ratios, the only thign that is basicaly the same is the top end of the motor, but it is a diffrent cam i belive also but not 100% sure.
