Hi,
i have been wundering if the liquid engines are just different cylenders and heads from the air cooled. Like can i use a 1985 crank or piston in my 1983?
Thanks eh!
Gasss ON!
Hi,
Thanks eh!
Gasss ON!
'85 ATC 250R
FMF Fatty & Power Core
Boyesen Rad Valve
38 PWK A/S
K&N w/PF (next purchase)
LSR +4 Axcaliber axle
LSR Duel row bearing carrier
DuraBlue Anti-fade (to be installed)
13/36 sprockets
'85 ATC 250R
Parts trike (maybe future build?)
totally different motors, you want something out of a 81-84 range...
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
BLAZERONE22,
kinda thought "but ya never know" sorta thing.
Are you selling them parts on eBay or....?
'85 ATC 250R
Boyesen Rad Valve
38 PWK A/S
13/36 sprockets
'85 ATC 250R
No, I'm ebayed out,
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
my piston rings are sticking to the piston, would too lean of a mix cause this? like the rings kind of spot weld to the piston causing loss of compresion but they break free every now n then. i guess it could b over heating, and that would b parcialy caused by too lean of a mix.
Could some awsome person measure the distance between the cylender bolts on a liquid cooled for me? (measure in an "X" and "L")
Thank you in advance!
'85 ATC 250R
Boyesen Rad Valve
38 PWK A/S
13/36 sprockets
'85 ATC 250R
