Thread: 185s rebuild
    Dec 2005
    New Jersey
    16
    185s rebuild
    I have an '83 185s that smokes enough that I feel a rebuild is in order sometime soon. It does seem to run well, however, it has a slight ticking that is audible at idle...don't know if this is normal or not. Anyway, while changing the oil, I removed the small oil screen (behind oil cap below recoil assembly) and noticed small metal shavings caught in the screen, which makes me think I should definitely inspect/possibly rebuild the bottom end. If I were to do so, what commonly gets replaced or what would you recommend replacing while the engine is apart? For the top end, I think I'm gonna go with a Wiseco piston/rings for the higher compression and hopefully will get a little extra power out of the engine. Is there a gasket/o ring kit that's available for rebuilding the top end or do I just have to order the ones I need?
    One more thing that's sort of off the topic: did the 185s ever come with a valve cover that didn't have a manual compression release lever? Mine doesn't have this and I don't know if it came that way or if it was modified...all I know is that if I don't pull the rip cord quickly and firmly, the engine will kick back and rip the handle through my fingers...geez, does that hurt!
    BTW, I probably didn't mention this in previous posts, but this is a great place with great people.
    Miami, Manitoba
    27
    I am not a motor guy but I did a little searching and found you a site that will help you on the gasket kit . heres the link: http://www.denniskirk.com/jsp/produc...ain&mmyId=9003
    Miami, Manitoba
    27
    hey and also good choice on the piston/ring combo. You might as well go all out while you have it apart
    Washingtons Crossing, Pa.
    2,977
    Before anything, I would get a good shop manual for it - I recoment the Clymer one. Next, I would give it a tune up. You cleared out the oil filter, now change the oil. To eliminate things - give it a Valve adjustment and adjust auto adjuster for the timing chain. If the tick noise goes away - it was one of those two common maintenence adjustments. As far as the piston replacement goes - you need to have the bore checked to see if its out of spec for stock. If it isn't - great, just a quick hone and install the new piston, if it isn't, its machine shop time, then they will tell you what size over-bore piston to get. I would also replace the timing chain while its apart. If you decide to go with the Wiseco - definitely get the 10.25:1 medium comp NOT the 12:1.
    Dec 2005
    New Jersey
    16
    Thanks guys! That's great information. Thanks for the link.
    What about the connecting rod bushing or the oil pump? Do those normally need servicing at the time of a rebuild?
    Does anyone know anything about the valve cover that I mentioned earlier? Thanks.
    Baltimore, MD
    6,088
    I'm not sure about what you are asking about the valve cover. In '81 there was a compression release on the valve cover that you had to push before you pulled the recoil to start it. On the 82 and later like mine, there is a cable that goes from the recoil starter to the head that moves the compression release every time you pull on the cable. I rebuilt one of these cable compression release recoil starters and I had to get some parts from the local honda dealer and some parts from bike bandit .com. If it is '82 or later compression realese if will have a hole for the cable ferrule to fit into. If it is earlier version, it will have a flat place where you use your finger or thumb to push it to engage it. Hope this helps. And personally, I myself have always like the honda manuals better than the aftermarket manuals.
