Results 1 to 3 of 3
Thread: I just bought this carb for my Z.
    May 2005
    Hobart, Oklahoma
    570
    I just bought this and then thought I would ask if it would work. It's a flat side 34mm so I figured it would be ok . I'm not looking forward to having to re-jet it but oh well. I've read where some people are using stock 250r carbs and are seeing some good results, but I didn't want to go to big. I don't have anything but a bolt on filter and a dg pipe/silencer. My stock carb is leaking gas and the inside is marked up pretty bad so I wanted to replace it.
    What do you guys think? Will it work?
    http://cgi.ebay.com/ebaymotors/Keihi...iendlyZ1QQpvZ1
    Sep 2003
    Elizabethtown PA
    1,581
    the 34 should work good for you your stock one is a 32 mm. the stock honda 250 carb is only a 35 mm so it should work okay also.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    na
    5,702
    well i think the only problem would be,finding a cable to fit it properly.i would think,a atc 250r 85-86 cable would fit your stock thumb throttle.but i am only guessing on that.
    Proudly NOT a member of
    "Team on the Teat"
