Thread: How hard is it to rebuild forks?
    toyota200x's Avatar
    toyota200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    402
    I have a 250sx and was wondering how hard it is to rebuild the forks. Also how do you tell if your frorks are blown? What parts would I need to buy?
    Thanks
    Nov 2002
    Youngsville PA
    47
    I rebuilt the forks on my 200x and it took quite a while but wasn't hard with a clymer manual. Check the fork seals to see if they are in bad shape or not. I would reccomend cleaning everything up good and getting new fork seals.
    Both the SX and X are very simple forks. Blown just means the seal is weeping oil. The bushing in the fork can also wear out and it won't work properly, replace it if it looks worn. Lay out a nice clean sheet and disassemble. I think theres an allen bolt on the bottom which holds the damping rod. Zing that puppy out and yank them apart, that is after removing the clip that holds the dust seal in the outer body. The oil seal will pop right out when you jerk them apart. Can't remeber if it has two springs in each with a spacer/collar, just pay attention. Manual would help but there are so few parts in there that laying them out in a well lighted area will be fine. Use the right oul and don't damage the seal or replace it. It's good to change fork oil once a year, cheap and easy to do.
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Here are some pics of a set of 250r forks being done. The sx forks are similar
    http://www.3wheeler.org/vb/showthread.php?s=&threadid=3718
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
