Results 16 to 30 of 37
Thread: the ATZ500 - Tri Z / CR500 Drag bike
    Mar 2003
    Kansas
    1,507
    in the gas tank silly.... lol Look close.. its there.
    Sep 2005
    Massachusetts
    1,272
    You can see the vent hose coming out near the handle bars like anyother quad, trike, or bike. But usually, the tank is under the seat. Kinda like my old lt185 quadrunner.
    Mar 2003
    Kansas
    1,507
    its just your basic relocated aluminum tank under where the airbox is on a stock Tri Z. Here is a pic of the one my other drag bike, this one is exactly the same.
    Mar 2003
    Barnesville,Ohio
    2,298
    wow! you did a great job on gettin it built. looks great!
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    amazing! I cant wait for the video!
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Mar 2005
    Parma. Oh-sub of Cleveland
    472
    that Z is the most beautifull thing. EVER!! great job man.
    Ryan
    1985 350x
    1985 Tri-Z
    1983 200
    Atc 70
    1985 200s
    -parts for sale
    1985 Polaris Indy 500
    1986 Polaris Indy 400 liquid-For Sale
    1988 GMC sierra 1500
    Oct 2005
    saratoga, ny
    2,819
    that thing looks like it should be sitting on the deck of a naval aircraft carrier ready for launch. damn that thing is saaaawwwwweeeeeeeeeeeeeetttttttt.
    Mar 2003
    Kansas
    1,507
    thanks for the compliments everyone. Im still gonna do some little cosmetic stuff to it, to really make it look evil.
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    Now you might want to look into extending the exhaust pipe.
    The flames are getting awfully close to that tire!
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Front royal, va
    2,186
    in the fuel tank above the engine! you can see alumium shining through!
    Aug 2004
    Ab Canada
    4,368
    So dose the stock Z tank not Fit under the seat with the cr500 motor? or was that just taken out for Dragin...?
    1985 Tri-Z-
    Mar 2003
    Kansas
    1,507
    Quote Originally Posted by My trike Sucks
    the thought of the stock tank never even crossed my mind, because this was 100% dragger from the get go. But.. there is room for the stocker to still fit Im pretty sure. I dont have any, or Id hold one up to see for sure (I cut all... and I mean ALL tabs off that were not being used, so I cant give a 100% either way) Infact a stock Z style airbox setup would work better, because the carb sits down below the back crossmember, and a straight back intake like I did was kinda hard to pull off without bending my intake boot outta shape.
    To be honest with everyone... this motor, in this frame, is not something you would want to ride for very long. It vibrates so bad, the only thing it would be good for is 300 feet passes, then let feeling comes back to your hands. Now I cant say for the Honda framed guys, but with my own personal experience, this thing is a vibrating monster. Im going to try those fasst company vibration inserts, to see if that helps. Also this next winter when I tear it back down, Im thinking of how to rubber mount the motor.
    we did that last year at the shop with a cr 500 motor in a 250R lobo frame weended up rubber mounting the motor and using the bottom mounts from a banshee by shorting them up.still shook like a mother so we drilled holes in the frame and nerf bars and filled it with rubber plastic dip and coated the kickstarter.break pedal and other stuff that shook violently helped ALOT just make shure every mount for the motor is rubber . ended up snaping all the mounts off a double jump so we tore it down and ebayed the motor, should work good for draging like you said only 300 feet.
    Aug 2004
    Ab Canada
    4,368
    i know on my IT465 dirtbike the Bar risers are rubber mounted...wonder if you could Make them work for the Z? would kill alot of the vibration i would think.
    1985 Tri-Z-
  15. #30
    Newfoundland
    5,280
    Yeah rubber mount the bar clamps and possibly the footpegs (trying to think of how) and that should dull the vibes.
