recently obtained an old junker 110 for 50$ - tore it down to peices and am just trying to go for a solid build - nothing crazy.
I wanted to start this forum because I will need some advice from time to time.
current status - carb is trashed, valves are more concaved than a new skateboard, and the cyl & piston look decent - I have yet to take any specs. got a good seat and new maier plastics.
I am still trying to figure out where to get the seals for the motor - like the bearing seal looking things - they look like minature rear main seals - they sure did not come with my rebuild kit! I should probably call KIRK back.
Oh - and could some one please tell me where this ball goes? I took off the high low gear cover and was about to remove the gears for storage during breakdown and noticed a little ball sitting there. a check ball or something? - I want to get confirmation before I go sticking it somewhere!
also - anyone wanna give me some ideas about cutting the new valves into the heads? is this just a eyeballed process that is going to fix itself as the motor breaks in?
thanks -
r4r
