Results 1 to 8 of 8
Thread: Got my KD80 need some help.
    Cody's Avatar
    Cody is offline Just Too Addicted Arm chair racerJust too addicted
    Feb 2005
    FLORIDA
    731
    Yea, the spark plug cap was gone. And so was the piece you screw it on. Im going to see if I can take the wire off of another coil and put it on there. But the thing is, it's getting major spark through the wire. But when I wrap the metal wire around the spark plug end I get nothing. Or does the cap matter? Should I change that wire? Anyway's it has compression, good spark (electricutes me), kicks over fine. What should I do now?
    1985 Yamaha 200E Shaft - New Toy / Project
    1983 Yamaha YT175 - Kinda retired?
    Aug 2004
    Ab Canada
    4,368
    Get a new cap and a new plug, your plug could be Toast.(see happen lots)
    1985 Tri-Z-
    Cody's Avatar
    Feb 2005
    FLORIDA
    731
    Nope, not the cap. Iv been using it. Iv tried dif. plugs. No go. Im thinkin points are dirty. Im going to pull the flywheel off tomorrow.
    Us
    727
    If your getting electricity through the wire to shock you, your points are fine (if it even has points). You need to get the proper cap and a new plug, that should be your problem. When you wrap the wire around the plug do you get spark on the plug?
    Sep 2005
    Massachusetts
    1,272
    Its too new to have points. You will need the right spark plug to make it run. You can just throw a lawn mower spark plug in it and expect it to run. Go to your local parts store and get a new cap and the right plug.
    Cody's Avatar
    Feb 2005
    FLORIDA
    731
    I pulled the cap off my DS80. I can see the points through the flywheel. You can see there dirty. It's an 87. Im pullin the flywheel.
    Sep 2005
    Massachusetts
    1,272
    I hope you have a flywheel puller then.
    Cody's Avatar
    Feb 2005
    FLORIDA
    731
    Yup my dad is bringin it home. Using screw drivers hurt the threads.
