Results 1 to 11 of 11
Thread: My reverse light don't work (250sx)
    Pa.'s Highest City
    8,058
    But my neutral light works just fine. I had the same problem with another sx I owned several years ago. Can someone help?
    Oct 2005
    Pennsylvania
    863
    Check the wiring diagrams-----There will be a wire that runs to the reverse switch
    (The neutral and reverse switches might be combined-I'm not sure)--ground the wire and check the light----Also check ALL ground connections
    May 2005
    Dorset United Kingdom
    1,408
    Quote Originally Posted by chrisr200x
    If I remeber right, The wire for the reverse switch goes to the engine case down by the right hand footpeg, Its quite vulnerable here and might have got broken, Its only protected by a small metal plate.
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    springville, PA
    6,185
    did you switch bulbs to see if one was blown?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Pennsylvannia
    1,147
    I have the same problem with my Reverse light. Sometimes it works, sometimes it doesn't. It doesn't really bother me though..
    '85 250SX - My first ever trike and my pride and joy
    **Check Out The Whole SX Project Here!!**
    '85 350X - 10:1 Piston, performance cam, '86 engline/carb
    '85 Powervalved Tri-Z - Fully modded - Soon to have a Corey Sprock 310 kit
    '85 250R - Began the modification process. This bike is going to scream! -295cc kit, Ported, Drag intake, 40mil Keihin, VForce reeds, shaved head, PT High Rev pipe, Fat Boy 2 Silencer, +4 Durablue axle, +2 swinger-
    Pa.'s Highest City
    8,058
    Quote Originally Posted by nouseforaname90
    But I thought you were a perfectionist?
    thanks for the replies guys. I wasn't able to get out there to look but it seems like an easy fix. anyone know where i can get a bulb from?
    Pennsylvannia
    1,147
    Oh believe me, I am a perfectionist, but I searched the wiring harness all over looking for the problem, and I coldn't find it. So I just figured it wasn't worth the trouble, and the bike isn't absolutely perfect anyway, right? lol
    Howdy's Avatar
    Celina, Ohio
    10,079
    Napa, Autozone, Ace Hardware, ect. I have purchased little bulbs like this at quite a few different places.
    Howdy
    Jul 2004
    Mud hill. close to water !
    3,658
    Common SX problem .. cuz mine does it too ! sometimes it works.. sometimes it don't.
    Currently :
    Bartlett TN
    3,083
    Quote Originally Posted by slothminx
    You are correct. 99% of the time when your reverse light doesnt work its due to a bad connection on the bottom of the engine area. I have had my 85 SX, 85 big red and even my 86 SX have that same problem. I would clean that area where it connects really well and maybe put some silicone on it to keep it from corrosion.
    86-87 Tecate ROCK!
    May 2002
    610
    check the engine case for the rev. wire connection. there are two, the other one is for the neutral lock out switch. that is probably where the problem is.
    Sam from Florida
    1985 BIGRED $ 200X
