Results 1 to 10 of 10
Thread: 83 r wont run
    smokey's Avatar
    smokey is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    ravenwood MO
    221
    83 r wont run
    I just put a new wiseco pistion and rings, fmf torque reeds and a different stator coil. I cant get it to start for nothin it has spark and its gettin fuel and it has compression. I dont know what else could be wrong, am i missing somthing because im new to 2 strokes. The oil is klotz synthetic mixed 32:1. Could the reeds be in wrong?
    85 ATC350X- weisco 10.25:1, uni, +3 swingarm, 3in. wheelspacers, RAD carrier, 450r muffler
    85 Big Red
    83 KLT200
    82 ATC200
    If it aint broke fix it anyway because it soon will be
    Poplar, WI
    531
    You are fine with the oil mixture. Check your jetting for sure, it could be off now that you have higher compression, proble better airflow via the reeds, check too see you have the right plug ( as in operating temp.) so you have a compatible ststor? Lastly, check and see you timing is all in check...and make sure the correct fuel lines go to the correct places.
    If nothing else, spray a quick shot of starting fluid in and kick on it. What temp. are you attempting to start this thing? Is it a dry or moist place?
    Charlie
    1983 250R ~ 1984 125M ~ 1990 POWER WHEELS!! trike
    smokey's Avatar
    Jun 2004
    ravenwood MO
    221
    How do i check the timing, i think i put it back where it was but i dont know if that was right cause i bought it in pices. What would be a good jet to start with? I think the spark is a little weak so im going to order a new stator.
    85 Big Red
    83 KLT200
    82 ATC200
    Newfoundland
    5,280
    Sounds like a case of the timing being off. If it were the carb it should at least make an attempt to fire.
    smokey's Avatar
    Jun 2004
    ravenwood MO
    221
    how do i adjust the timing? Its behind the flywheel right?
    85 Big Red
    83 KLT200
    82 ATC200
    Newfoundland
    5,280
    Not sure on an R but yes its the stator plate behind the flywheel. There should be a mark on the stator plate and a notch inside the stator housing that line up with each other.
    James
    Air-cooled-R's Avatar
    Air-cooled-R is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2005
    West Monroe, LA
    167
    To adjust the timing on an 83 r you have to take off the flywheel. The stator is held on by 3 bolts. These bolts are in slots, it's a good start to loosen all the bolts and line the stator up so that all the bolts are in the middle of the 3 slots. If it fires, but doesn't run how it should, you can advance the timing by spinning the stator/stator plate clockwise or retard the timing by spinning the assembly counterclockwise. I was having the same problems out of my 83r a while back, it just turned out being this problem....... hope you get it worked out. Oh yea, I've got a seat in my shop, its in decent shape, but the cover has some holes, but the foam seems to be good, and I've got 2-3 old sets of fiberglass fenders and the brackets, but i dont have a shifter. If you want it, I'll look into how much it'd be to ship and tell me how much you'd want to give for 'em. Sorry, but no shifter..
    My bikes:
    -1982 honda 250r
    -1999 HONDA 300 Fourtrax 4x4 "The Tank"
    -2001 harley 1200 sporty
    Oct 2005
    West Monroe, LA
    167
    I tried to PM you back, but it said that you didn't accept them, so I put it on here. 50 plus shipping? I'm almost positive I have the latch but I'll have to check to be sure........
    My bikes:
    -1982 honda 250r
    Washingtons Crossing, Pa.
    2,977
    Just to clear up some info - Compression changes and or Reed changes usually don't require re-jetting. I say "usually" because every machine is different, but this is a generally accepted rule. The head is just compressing the same amount of charge, and the reed cage is after the carbouration has occured, so while it might allow the fuel charge to flow freer, it dosent change any fuel to air ratio. Also, neither Boyesen or Pro-flow mention jetting as a concern with installation of their products. Speaking of reeds though - hard starting can easily be caused by worn, mis-fitting reeds. Take out the cage and check for daylight where the petals seat. If there is a noticable gap, you could have problems starting.
    Jun 2004
    Oregon
    1,783
    Could it be the ground? I had a problem with my r after i painted the frame..My ground wasn't clean enough and it wouldnt run..Scrached out a spot made a new ground and it ran great..
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
