Thread: Steering stem change?
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Is there any way I can change the steering stem of a 83 big red to a 82 big red? the 83's stem is shorter and cant thread on. I was going cut it off with a wafer disk and weld the other one on, would this work??
    Russ
    TF 07,08,09,10,11,12,13,14!
    Howdy's Avatar
    Celina, Ohio
    10,079
    The forks are same on the 82-84 Big Red's. I have swapped them out before. You can verify this by looking them up on www.partsfish.com. All 3 years part numbers for the triple tree set up is 51400-958-680.
    Howdy
    Mar 2003
    3,092
    I see, but it makes no sense because the stem on the 83 is as a couple inches shorter than the original. I'll mess with it, but I'm sure its to short, but the front end looks identical except for the stem. If all else fails would it be possible to just cut the short stem and weld the regular sized one on, just grind the weld off so its smooth?? Thanks Howdy.
    Russ
    Randolph NY
    597
    We will snap some pics for you guys once its done, A steering stem taken from the original forks to the new... lol, should be interesting!
    springville, PA
    6,185
    make sure the stem is pushed up all the way. When i first put the 200x front end on I didnt have it just quite right so it seemed to be too short.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
