The Z was runnign like crap with the stock carb, it had a 490 main. It wouldnt rev right out.
I got a 38mm Mikuni TMX carb off an 92 YZ250 for it. The jets that were in it were 320 main and 45 pilot. I got it hooked up, and started it, It revved way up. Full throttle. I checked to make sure the slide was all the way down, it was.
So, then next thing i did was check for air leaks. I sprayed water all around the boots and it didnt rev down at all.
I tried bigger jets tonight. First I put in a 350 main and a 55 pilot. Started it, revved way up again, so P.O.'d as I was, I put in a 420 main, and a 65 pilot. Started it, revved waaaay up again. Whats going on? MTS thinks it may be the left crank seal sucking air.
Why would it idle with the other carb then?
