Results 1 to 13 of 13
Thread: Tire spins on rim....
    I got a set of new Dirt Devils on steel wheels. Since I got them one side has broke the bead a few times at under 5psi and leaks out the bead unless I run about 8 psi. There is no damage whatsoever to the rim or tire. I have had it unmounted and remounted with beadseal and it then broke the bead when driving in the snow. These tires are cheap 2 ply tires and I wonder if they are just useless. What on earth can be done to fix this? Should I break the bead, clean it and contact cement this thing on there??
    Baltimore, MD
    6,088
    I would break the bead and make sure there is not alot of rust or some oil or grease or something on the bead. Don't use the contact cement unless you want to have serious problems later, major pain in the butt. If worse comes to worse, you might look into innertubes, just a suggestion. Try cleaning the bead seating area on the wheel, you might have to wipe down with mineral spirits or something if it has grease or oil. I hope you didn't try putting your tire on with wd40. Don't laugh, I've seen it done.
    Jan 2005
    Tennessee
    850
    I would just use a tube. Goodyear can put them on for you and there cheap. My dad did it for me. He works at Goodyear.
    Aug 2004
    Ab Canada
    4,368
    i had this same problem with the OEM Ohsu's on my a ATC 200......Cleaned and painted rims still didnt work, i think the tires where just junk for sitting so long...it would spin both rims in the tires...VERY anoying...
    1985 Tri-Z-
    These are Brand New - No oil grease, dents.... nothing. Running a tube will never work because the problem with tubes is that if the tire slips it rips the valve stem off, not to mention that I hate tubes!! I'm just wondering if the tires are simply too cheap and flimsy to seat properly and would new Douglass aluminum rims hold better?? These tires hook up well in the snow and it's a shame to not be able to use them..
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I had this problem with some holeshots on OEM honda wheels. Go to NAPA or an autoparts store and ask for a bottle of bead sealer. Its black nasty tar looking stuff. Break the bead on both sides and liberally smear it all over. It should do the trick.
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Your other option is to go to 10" tires and wheels.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Aug 2004
    Ab Canada
    4,368
    You Could try taking a Chisle, or air chisle(wich ever you prefer) and put Lines On the Edge of the rime Like a stamp almost where the bead seats, They use it on Big tractor tires to keep them from slippin, could prolly use it on a ATC rim...at leas try it...
    1985 Tri-Z-
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    What about bead locks? Don't they make those for ATV's?
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by crackshot
    Got 300$ for a rim?
    1985 Tri-Z-
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by My trike Sucks
    Got 300$ for a rim?
    Burgards Cycles makes 8" beadlocks with a inner ring for $110 each.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Nov 2001
    B.C.
    933
    Use tubes and screw the tires to the wheel....an old drag race trick....
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    smokey's Avatar
    smokey is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    ravenwood MO
    221
    On my big red the tires were cracked bad and wouldnt hold air so I put tubes in them and spun the tire and riped the valve stem out. So I put in new tubes and screwed the tire to the rim with about 20 sheet metal screws and havnet had a problem since.
    85 ATC350X- weisco 10.25:1, uni, +3 swingarm, 3in. wheelspacers, RAD carrier, 450r muffler
    85 Big Red
    83 KLT200
    82 ATC200
    If it aint broke fix it anyway because it soon will be
