Don't waste your time or money on this trash. I followed the instructions and the first time I washed it half of the stuff came off. Their customer service sucks too.
Sounds like you didn't prepare the plastic properly ...... I wouldn't recomend it either - but - for different reasons. While the finished product ends up looking good, you need to put HOURS of sanding and resanding into it. Its just not worth the time if you ask me.
I was skeptical on using it too. Thats like plastic polish too on convertibles with clear plastic rear windows. You can use the stuff every week to keep it from "fogging" but all it does it keep it pliable so it does not crack as fast.
What were you trying to "renew"?
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
Best thing I found was polishing compound and a buffer.
I did all of the plastic on my 350x. And yes I prepared it properly. I have body shop experience so I know how important prep is.
i dont mess with that stuff i just go stright to color sanding it may take longer but the out come will please the hell out of you. here is what i did to my tank on my 86R with a little time and wet dry sand paper.
Use an air power polisher with a low to medium cut compound. We did that to my front fender on my YTM, it looks brand new, you can see your reflection in it.
Dont waste your time with that renew crap, it washes off
We also use that to clear the lens up on the sandblasting mask when it gets pitted to bad.
Plastic Renew works great if you ask me. It did require lots of sanding, but if you follow the directions and buff with steel wool and re-apply three or four coats like it says, it won't just wash right off. It also says not to use any kind of soap when washing.
1984 ATC200S
1984 ATC200X
1984 ATC200M
1985 ATC200X
1985 ATC350X
1985 ATC250R
1986 ATC200X
1987 ATC250SX
TPC450
iv used it and think its great stuff...but red is the hardest color to get to look good...never had it wash off ether
WWW.HREATV.COM
