200s cylinder head locating dowel question...need help quick
I reassembled my 200s motor without one of the two locating dowels. They fir between the cylinder and cylinder head. I used a OEM gasket, and the dowel didnt fit inside of the gasket, so i left it out. I have since bought a complete gasket kit, so now i have the gasket where it will fit, but the motor is back in the frame, but i havent started it due to not knowing if itll hurt the engine or not, and i've had other projects since then.
Is it OK to leave the dowel out? Whats the point? So the head doesnt move, or is it for oil to get up to the cam... If the motor is torqued down, will it leak oil from that spot, and will any enging damage be caused if the dowel isnt used?
i REALLY dont feel like tearing the top end down since its already in the frame, even though it isnt bolted in yet. Of course, if I HAVE to, i will, because i dont want to ruin my little 200s haha.
THanks,
Mike
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
