Results 1 to 15 of 15
Thread: 250 sx question
    3leggeddog's Avatar
    Nov 2004
    250 sx question
    does the battery have to be hooked up,and operating to get spark?isn't that the purpose of the kicker?i still have no spark on my sx.i have not tested the componets yet,gonna do that tomorow.just curious if the battery plays a role in the spark issue.
    Air-cooled-R's Avatar
    Air-cooled-R is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2005
    West Monroe, LA
    167
    It shouldn't. I'm pretty sure all *Edited* have to do is have the wires together, or have a dead battery there, just to complete the spark's circuit........
    My bikes:
    -1982 honda 250r
    -1999 HONDA 300 Fourtrax 4x4 "The Tank"
    -2001 harley 1200 sporty
    Pennsylvannia
    1,147
    I don't think the battery has anything to do with it.. as far as I know, all you need is to have a battery there. (Actually I'm not even sure if the battery has to be there at all.. lol)
    Dec 2002
    Janesville,WI
    573
    If it doesn't start with the kicker,check the cdi box.
    85/86 ATC 567x
    Bailey(11/30/97-4/17/06) My little angel
    3leggeddog's Avatar
    Nov 2004
    well i don't have the battery hooked up,can that be it?
    springville, PA
    6,185
    the battery has nothing to do with it. my SX doesnt have a battery on it. When i got no spark it was my CDi. Should be a good starting point.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    check the neutral reverse wire as my 250es had no spark and the reverse switch wire was cracked
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    No battery is needed, check for problems in the on off switch before anything else. I've seen the soldered connectors come off many times...
    3leggeddog's Avatar
    Nov 2004
    well i still got no spark.the starter is turning over now,but there are no gears inside the case?i took it apart to find alot of things aparently missing.are these gears hard to replace?
    i got power to the starter,but no neutral light,i will check the assembly again
    springville, PA
    6,185
    have you tried kicking it over to see if there is spark or just electric starting it?
    Nate
    R.I.P HRR
    3leggeddog's Avatar
    Nov 2004
    i tried kickin it,no spark.thats why i wonder whats going on.maybe in the stator assembly?someone has had it apsrt,because all the electric starter gears are missing in the left side case.maybe they screwed something up in there.
    springville, PA
    6,185
    or they just removed the gears. Make sure your getting a good ground and that all the electrical tests out before you rip into 'er.
    Nate
    R.I.P HRR
    3leggeddog's Avatar
    Nov 2004
    well tomorow i will do all the electrical testing.i wanna see whats going on.seems wierd though.
    i dunno,who wants to fix it for me?howdy,got time?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by 3leggeddog
    Bring it over Saturday morning and we will get you all fixed up ( while you wait ). Heck, you might want to stop and pick up Derrick and bring him along as well. I have something he may be interested in.
    Also, I might even have P3 #2 going by then and you guys can break it in for me. lol
    Howdy
    3leggeddog's Avatar
    Nov 2004
    darn howdy,i got to work sat. morning.what do you got going sunday?maybe i can cruise up then?
