Thread: Rear axle seal on '85 Big Red
    Maine
    3
    Hey there everyone
    I'm a new member to this forum. I just picked up my new ride. It's my first three wheeler (I've ridden them plenty). She's an 85 250es Big Red. She's all original, and in mint shape. Well, except for one thing. On the rear axle, on the left, there is a small leak. The guy I bought it off of had the seal, and assured me that it was not a big deal to replace, but does anyone have any suggestions/thoughts/warnings about changing this? He couldn't find the manual for it, but said that he was going to send it in the mail once he found it. What is the level that the oil should be at in the rear end?
    Any help that anyone can give me would be greatly appreciated!
    Thanks,
    Sol.
    Jan 2005
    Great Bend
    704
    I cant help ya on the big red, I own nothin but race trikes.
    but, welcome to the boards, there are planty of guys on here that will help you out.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    when i have changed the fluid i fill it up to the bottom of the threds of the filler hole unless theres a small bolt on the side of the diff. if there is remove it and fill till it comes out,I can rember if there is or not?
    Bartlett TN
    3,083
    Here is a great source for manuals. Just print out the PDF file and you have your manual.
    http://deepa.recongamer.com/hondamanuals/index.html
    Also the seal he gave you probably is the rear diff seal. The axle is actually dry but you have seals in the diff and in the brake hub area.
    86-87 Tecate ROCK!
    Brandon, Manitoba
    2,209
    I fill the diffs right up to the top too. There isnt a check screw on the big red, just pour it in slowly til it comes out the fill hole.
    Quote Originally Posted by Yamahauler
    thats what i thought it been a wile since i did one thanks for clarifing that for me!
