ahh!!! 34mm CARB?! The original carb on the 200x was a 24mm carb...DANG but ok I made my 200x a so-so "race trike" . I used everything and have the stroker crank in a box just don't have time to put it on yet. What i did, was go through www.powroll.com . This site is awesome. I put the 198cc kit, midrange cam, stiffer valve springs, bigger valves, XR200R carb, ported an polished head, UNI filter, Cobra pipe, and the wiseco 10:25:1 piston, or as i believe it is that compression i am not all that sure. Also, as i said before, i have the stroker crank but just haven't put it on. This is makes the trike very quick, but if i were you, I would put the money into the 350X. I mean all the mod's that i did make the 200x an awesome trike(with the crank) on the track but i am sure a 350x(no doubt really) with good suspension would beat it. If i keep it for a while more, I am going to put the crank on it and put heavier duty clutch plates and springs. And find a better bottom end because my kicker gears are really not all that great and possible progressive springs and possibly an oil cooler for cooling. Will probably put more money into my R though. Good luck! And we need PICS
EDIT: to answer your questions, overheating is not much of a problem with my trike so i wouldn't worry to much about it. To run regular petrol, go 10:25:1 and NOT 12:1 or else you will need race gas.
Rest in peace Rex Carlson
