Results 1 to 14 of 14
Thread: clutch woes
    Jan 2005
    RI
    2,530
    clutch woes
    I bought a new cable for my 85 r...i installed it, put the bike in gear, pulled the clutch lever to put the bike away, and pushed the trike, but the wheels locked up, like the clutch was still engaged. I adjusted it to its max at both adjustments, and still nothing.
    I dont get how it was fine before i took it apart, and now it acts like the clutch lever means nothing.
    I put the old cable back on, adjusted it to where it was before, and still nothing.
    Can you pull the clutch lever too far and have it engage the clutch again? Like how its at the max adjustments, the cable would travel too far and make the clutch engage again?
    I just dont understand this. What can i do to fix this? How hard is a clutch on an r to change? I remember hearing about the clutch update thing from a newer trx250r, but i dont remember.
    Please help me out here.
    Thanks,
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Brandon, Manitoba
    2,209
    If the bike is not running and its in gear, you can pull the clutch and it will still drag. Completly normal. I couldnt figure out why my Z did that, then someone told me its supposed to happen.
    Start you bike up, pull the clutch and put it in first. It should be fine!
    Jan 2005
    RI
    2,530
    i did, and it stalled out because of the clutch
    anything else? all of my other bikes i can pull the cluch and start the bike in gear...i try it on this one, the bike moves forward
    i dont get it
    Thanks,
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Brandon, Manitoba
    2,209
    Is the lever on the outside of the case ajusted properly?
    You'll probably have to pop off the clutch cover and play around with the internal ajustment.
    When you take it apart, make sure all of your linkages are in good shape and arent worn.
    My pushrod that connects the lever to the pressure plate was worn right down becuase my adjuster screw had a bend in it. The clutch pull was hard as hell for a while, then it finally wore that pushlever down, and the clutch wouldnt disengage.
    When you pull the clutch, can you feel the springs compress?
    Jan 2005
    RI
    2,530
    yeah, i think so...theres a lot of resistance...actually i dont really know, ill have to check into that tomorrow...maybe ill pull it all apart, check everything, and reassemble as long as everything isnt worn.
    Maybe thatll help it some.
    Thanks, and keep those opinions comin haha,
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Brandon, Manitoba
    2,209
    Check your basket for groves from the plates. They can get caught in them and not disengage.
    You will probably see some grooves in it, take a file and make it flush. That way you know you dont have to worry about it!
    Aug 2002
    New York
    1,098
    The Honda clutch has a couple problem spots. If you're having trouble finding your "sweet spot" on your clutch it's most likely a worn "clutch release arm" (what your cable connects to on the motor) or as Yamahauler suggested, the pushrod assembly is bad. The ATC clutch pushrod had a ball bearing at the end of the shaft that wasn't a very good design. It can bind up, causing damage to the whole assembly. The 89 upgrade kit will relplace all of the affected parts except the clutch release arm.
    Grooves in the basket are a likely contributor as well, but that ususally causes clutch slipping, not what you're describing.
    I would get the 89 TRX clutch upgrade kit as well as the "clutch release arm" while it's apart. It will cost under $100 to fix it and you will be all set for the next 20 years. Also, as Yamahauler suggested, I would carefully file down the grooves in the basket while you have it apart.
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    What years clutch baskets will fit an 85R?
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Aug 2002
    New York
    1,098
    85 or newer ATC or TRX baskets will fit.
    Jan 2005
    RI
    2,530
    i finally got it all disassembled, and the plates look ok, the lifter and ball bearing are perfect, and the rod connecting the cable actuator is nice and straight, and the acutator is perfect. The basket had very small grooves which i filed nice and smooth. I think im going to do the update kit anyways, due to the fact that the clutch is still at the max adjustment.
    I reassembled it, pulled the clutch, and pushed the bike and it moved. Not completely free, but it moved. I am goign to order a clutch kit somewhere, with stock springs, and grab that update kit.
    Thanks for your help,
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by DeePa
    Mike
    Did you install a new gasket or use old one?
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    CUYAHOGA FALLS, OHIO
    1,242
    Adjustments
    Quote Originally Posted by Yamahauler
    Their are no internal adjustments.
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Jan 2005
    RI
    2,530
    there are no gaskets installed yet...i just put the clutch basket, plates, and pressure plate back together to keep everything neat and organized. THe cover is still off. I have a new gasket. I just ordered the update kit, and i have to figure out good clutch friction plates and i may just get the steel plates and springs for the extra 10 bucks.
    How is this deal on ebay?
    http://cgi.ebay.com/ebaymotors/NEW-B...19772485QQrdZ1
    or
    http://cgi.ebay.com/ebaymotors/HONDA...11627898QQrdZ1
    thanks,
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Brandon, Manitoba
    2,209
    Quote Originally Posted by max
    Must be differant than a Z then. The Z has a adjuster rod and a lock nut.
