Thread: This is probably......
    This is probably a stupid question but, :? where is the idle screw located on a 2003 Yamaha Blaster? I looked on the right side and the left side of the carb and no screw. I only see the air mixture screw. There is a hole on the right side of the carb that has threads in it but no screw. It looks like where the idle screw might go but Ive read the manual and it dosent show that as being the idle screw. It shows something else but the picture isnt clear and is confusing.
    2003 Kawasaki KLR 250, 2000 Kawasaki KE 100, 1985 Honda ATC 125m, 1985/6 ATC 350X, 1979 Honda ATC 110. 1993 Dodge Daytona IROC V6 5 speed
    Detroit, MI
    837
    You have to take off the seat, and it should be very visible with the seat off near or on the carb. With the T.O.R.S. crap I think it's actually moved from the carb. You should see it though with the seat off.
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    Thanks you HemiChallenger71.
    May 2002
    Texas
    2,670
    How do you like the '03 so far?
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Truthfully I have to admit. Im a Honda and Kawasaki person. But I havent had a chance to really ride the blaster only for a hour because here in Southeastern Massachussetts with all the snow and slush and the periods of warm weather it makes the ground REAL muddy so the tires just spin . But taking it down the street so I can see what it has...., for a Yamaha its allright 8) . Its real quick for what it is. And I cant wait till the gruond is decent enough so I can ride in some of the pits around here.
