Results 1 to 15 of 21
Thread: Boring out my 85 110
    So, I want to bore out my 1985 110 motor. Is this a good way to go? Should I just buy a bigger engine and slap it into the 110's frame?
    Also, a few links on pistons and such would be great. Thanks guys!
    Mr. Overkill
    "Overdue it to do it right!"
    ((Post #1 @ Thu Nov 06, 2003 1:56 pm))
    springville, PA
    6,185
    wiseco.com. If you want more power try to find a high compression pistion for it too because boring alone wont give you the effect you want. Also you might want to think about regearing.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Nov 2002
    Kirkville, NY
    3,831
    No, I wouldn't bore just for more power. By just boring you will only gain a couple of cc's. Unfortunately the biggest engine that will bolt in is only a 125cc so that doesn't give you many more either. I would say the best way to go is to bore it the next size up just to freshen it up, find a higher compression piston, get a performance cam, performance exhaust, and then re-gear it. If you want more power then that and have deep pockets do a search, there are a few Honda 110 projects going on now by other board members.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by thefox
    I agree 100%! Though I will add a option. You might be able to have the motor stoked ( BIG $$$ ). This would give you more power. But it will also take away from the long term durability of the motor.
    Howdy
    Jul 2004
    Mud hill. close to water !
    3,658
    Just buy a 250 R and a good quality helmet ! lol....
    Currently :
    springville, PA
    6,185
    Quote Originally Posted by bigredhead
    Where is the challenge in that ? I'm going overkill on mine to enter it in the kids class. One kid has 2 small cc Scramblers that always win, well its time for him to move over.
    Nate
    R.I.P HRR
    PA
    3,515
    i say do it.....for a cheap big bore i know a atc 125 piston will work....then get a cam and pipe....and maybe a 185 carb youll be set...lol
    my 110 has a custom high compretion piston
    mega cycle cam
    cobra pipe
    185 carb
    and a huge port job
    as long as you keep it wound up it runns real good!! but a bigger piston will add much needed tourque
    WWW.HREATV.COM
    So a 125 will fit into my 110 frame? If I got the 125, bored that out and got a good piston and stuff, wouldn't that be better?
    Mr. Overkill
    PA
    3,515
    no...i meant use a 125 piston in your 110 motor....just a thought
    WWW.HREATV.COM
    Jul 2004
    3,658
    For the amount of power you get.. the tradeoff is reliability.. keep the 110 as is and get something with balls if you really want to go fast..
    I do understand the appeal of having a small machine that rips.. but in all honesty, the gains are not that great for the amount of money involved.
    It's like converting a trike to a quad.... what's the point ?
    Currently :
    PA
    3,515
    the point is its fun and different...lol
    WWW.HREATV.COM
    Central CA
    459
    I remember a year or so ago some dude posted pix of a 200 motor machined all to heck with the cylinder pointing forward and it was going into a 110 but nothing came of it. Anyone remember that one?
    Found it:
    200 in a 70
    86 250R
    86 250R
    86 250R
    85 250R
    82 250R
    86 350X
    81 185X
    85 250SX
    87 200X
    Sitting on my can can, doing the pan-o-ram..
    Rittman, Ohio
    6,276
    Boring is not a performance modification and should not be done for that purpose. Its purpose is to clean up defects or uneven wear in the cylinder wall.
    Baltimore, MD
    6,088
    I believe that 200x was in a atc70! That would be greenhumans atc70. That thing would probably rip the eyeballs out of your sockets. I want one. I would put it in one of my suspension 70s'.
    Feb 2006
    Central Florida
    1,090
    you can always do what the rednecks do, and weld a 350 sbc on the frame!
    quiet people seem intelligent
