Results 1 to 9 of 9
Thread: help
    new brunswick
    39
    help
    hay all i need some info. how do you get the little pin out of the magneto asemble so i can get the side open and fix the gear for the gear indicator thanks
    andre
    Jan 2005
    RI
    2,530
    It would be helpful if you tell us what machine you need help with.
    I have a bunch of service manuals free to download. Http://deepa.recongamer.com
    maybe ill have the one you need and then you can look up the problem in the manual.
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    new brunswick
    39
    that would be nice but i don't crosse me fingers because it is a 83 suzuki alt 125
    andre
    new brunswick
    39
    i actually only need to take otu the flywheel but i don't know how this is my first trike and had an oil leek as well at a cause of the gasket on the side the broken gear is on so no matte how i look at it i need to take the fly wheel off
    andre
    Howdy's Avatar
    Celina, Ohio
    10,079
    To remove the flyheel you will need to remove the nut on the crank. You will then need to use the special puller and the flywheel should pop right off. If memory serves me correctly the puller is the same one used on most honda 185-200cc motors ( 185, 185s, 200, 200s ).
    Howdy
    new brunswick
    39
    ok but i don't have a puler. so where could i find one and for how much
    andre
    Howdy's Avatar
    Celina, Ohio
    10,079
    You can find the pullers on Ebay, denniskirk.com and many other places. Before you run out and buy a puller we need to confirm which one you need. I'm at home so I can't confirm anything right now. If I have time tomorrow I can try to check for you ( I have Suzuki flywheels and a bunch of pullers ).
    Howdy
    new brunswick
    39
    thank i will be on and off all day tomorw
    andre
    new brunswick
    39
    would there be any other way to pul out the the fly wheel without a puler
    andre
