Results 1 to 7 of 7
Thread: Specs on Kawasaki?
    Escondido, CA
    32
    Specs on Kawasaki?
    Hey, anyone know what the specs are for checking the Coil / CDI / Stators on a 1984 Tecate? And how I check them? Thanks guys!
    Sean
    1994 Ranger prerunner / not running
    1984 Kawasaki Tecate3 / not running
    Escondido, CA
    32
    nobody has a clue?
    Sean
    Jun 2002
    Mississippi
    2,552
    i no longer have the manual. Getting one would be a big help to you. i used to run a compete 82-88 kx250 ignition sytem on my tecates. it revs faster, makes more power, and the magnets are screwed on. the only problem is that you no longer have a headlight.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Apr 2003
    Central New York
    1,860
    I do
    Get her all together and Hold the Plug while your Girlfriend Kickes her over. If you jump at least 5' high and Flop all over the Ground, your system is good.
    Make sure to play it up real good even if you dont get shocked and maybe your woman will give you some " Sympathy Time"
    Seriously I got the Book here somewhere but My little Place is full of Trikes and Stuff and Im all Jammed up. I will try.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Jan 2005
    Great Bend
    704
    if no one else posts it up by this evening I will get my manual and scan it in. I'm at work right now and my manual is at home.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Enigma's Avatar
    Enigma is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Born/Raised San Diego, CA. Currently Germany
    192
    Is this what your looking for? Im not sure how to check though.
    85 250 R extra bike
    85 tecate 3 brothers bike
    86 tecate 3 my bike
    Oct 2005
    saratoga, ny
    2,819
    i wish some one would scan and post a tecate manual on here, would help alot of us out.
