Thread: Need multimeter help for coil!
    Brandon, Manitoba
    2,209
    The manual says to set the multimeter R X 1. What would this be on my multimeter? 2000k, 200k, 20k, 2000, or 200?
    Also, how can you check the condenser?
    Feb 2006
    Canada
    Its just a multiplaction factor Rx1 the 200 should do. The condensor is basically a capacitor do you have a capacitance meter.
    Brandon, Manitoba
    2,209
    Ok, I tested thhe coil, the resistance between the spark plug wire and any wire (even the body of the coil) read nothing. I tested this on all OHM settings. I took off the plug wire, checked the resistance from end to end. There is 0.4 OHMs on the 200 setting. The other settings wont make a reading. So, does this mean the plug wire is screwed?
    Also, I checked the continuity of the spark plug cap, there is NO continuity through that.......
    Guess I should of checked these things for myself, i had took it to a small engine guy and he said my coil was perfect...HA
    Richland WA
    808
    Quote Originally Posted by Yamahauler
    The spark plug wire has to read something, its usually 5,000 - 10,000 ohms. If not, its open. Make sure the meter probes are making good contact. The spark plug cap might read 5000 ohms if a resistor cap.
    The plug wire reading of 0.4 ohm is the resitance of the meter and its leads, not the plug wire.
