If my trike runs and drives tommorrow hopefully.....ill post something when i find out....WISHIN MYSELF LUCK!!!! :-D
good luck to you.
i just got mine back together and am real sure i got the timing off 180 degree's - grrrrrr ! will tackle that issue tomorrow night,,, maybe.
anyway i hope yours fires right up for ya.
john
Not to insult you or anything...but how did you get it 180 off???? I HOPE MINE FIRES UP QUICK TOO!!! best a luck to ya!
good luck!
YAMAHA'S: 84 225DXL
04 POLARIS SCRAMBLER 500 4X4
05 kazuma 50
speed20, i put the cam in with the lobes up and they should have been down or no pressure on the valve train (compression stroke-tdc).
easy fix,,, rotate the cdi pick up thing (it was off too by the way)
i had to have the mrs. give me a pull start but otherwise mine fired up okay. didn't change my kicker shaft when i had the cases split so it has a slip spot where it don't grab,,, oh well,,,, it starts good enough for this year
