Results 1 to 15 of 26
Thread: How much power out of a 70???
    knsmodels's Avatar
    knsmodels is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2005
    Bucks, Pa
    318
    How strong is a stock 70?? Should it be able to handle a 250lb adult without a problem?? I got one for my son and it seems fine when he is riding it but when I ride it, it seems to fall on it face as soon as I try and shift out of first gear with it. I never had one before so dont know how much weight they can handle. Maybe the engine is just tired and needs a rebuild.....like I said it runs fine with my 6yr old driving.....just curious......Thanks....Paul
    86 350X
    86 200X (son's)
    86 250sx (daughter's)
    84 70/125lifan
    68 SS Chevelle
    72 4X4 Chevy Truck
    Click to see what I do
    Jan 2005
    Tennessee
    850
    I would think it should carry you. I just bought one and also weigh close to 250. So I hope so anyways. I did a search on this forum and its seems alot of adults ride them also. I am a little worried now, I read that if the front fender is hitting the head bolts it could mean a bent frame or forks. The frame looks staight, not sure about the forks. Mine just barely rubs, but I think my fender my be aftermarket also.
    Nov 2002
    Kirkville, NY
    3,831
    It should pull you arond ok so I would check it out, how does it run otherwise? As for the bent frame, take off the tank and if it looks like it is dented then it is time to look for another frame.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jan 2005
    Tennessee
    850
    The frame is perfect. I have it completely taken apart for a paint job. I think it may be the forks or the plastics may not be stock. Look at the picture of my frame towards the bottom of this page and tell me what you think.
    http://www.3wheelerworldforums.com/s...ad.php?t=49966
    Do you have any pics knsmodels?
    Nov 2002
    Kirkville, NY
    3,831
    hancadam - It looks like your forks are bent a little too me, the frame does look good though.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jan 2005
    Tennessee
    850
    I thought the forks did also. I will check into that when I get home. Thanks!
    dufrain's Avatar
    dufrain is offline At The Back Of The Pack Arm chair racerFirst time rider
    KY
    239
    That 70 should pull you easily.You will know if the motor is worn out by the blue smoke.I would clean the carb bowl out,the screen in the petcock and flush out the tank.
    85-70,79-110,79-110,80-110,86-250ES,85 250r,86 350x,82 250r
    Brandon, Manitoba
    2,209
    Thats crazy, I didnt know the 70's were luggin 200lbs+ guys around!
    Eastern Long Island
    1,688
    Quote Originally Posted by Yamahauler
    What's this luggin stuff. 6'4" and 215#.
    Lots O Trikes!!!!!
    TRIKEFEST 03, 04, 05, 07, 09 Going the distance
    Brandon, Manitoba
    2,209
    Quote Originally Posted by 200xman
    Hahahaha
    That is awesome, as my dad would say when I sit on my 90, looks like a dog trying to hump a football!
    Phoenix, AZ.
    6,719
    I want to get a 70 just to ride to the end of my driveway to get the mail. In full MX gear.
    Baltimore, MD
    6,088
    You might want to check your clutch, it could be worn or out of adjustment. About the front fender hitting the head bolts or the tank, check the stop for the front forks attached on the lower backside of the frame head, if they get bent out of shape, it will do the same thing, let the forks turn too far. A little heat and some persuasion with a usually will get the stop back into place. Make sure to either remove the fork bearings or to clean and repack them with grease later.
    Ontario, CANADA
    4,538
    Quote Originally Posted by Dammit!
    LMAO! I want one too, just to put around my local town. Right on the sidwalks "put put put" lol
    I want a 70!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Phoenix, AZ.
    6,719
    Quote Originally Posted by Kintore
    I want a 70!
    What's funny is my driveway is only one car length long!
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,245
    its taken you guys along time to figure out what i have known since 1979 when i bought my first 70!!!!!!! 70'S RULE TOO,,,,,,, I STILL HAVE IT TOO AND 3 OTHERS ,,,,
