dotn think odessey... wont fit at all and they are automatic.... think 480.... only difference from a elsinor and the 250R is a flywheel, stator, and forward kicker... my bottom end on my 83 R i just found out is a elisnor tranny (reason i only have 4 gears..no the shift forks arent broke...) the 480 is doable, like i told you before i might pull that off with the 3 other swaps iam going to do this summer... the 480 requires the lower cradles to be notched "dimbled" and some guesseting... but when done the thing will rip like no other bike... from factory they made a impressive 55 RWHP and are very capable of hitting 65+ with the right stuff i have even done some research and aim thinking with the right stroke plate you could fit the 480 rod into a 250R bottom end... for a stroked application.... it can be done, all original motor mounts can be taken off.... and its going to take some time to line it all up... but it can be done... remeber these motors where and are known as the first drag motors, suprisingly alot of the people on planet sand are familiar with this motor and i have heard of several of the first drag atc's hittin 4.2's in the 300FT back in the late 80's... i say go ahead try and pull it off... it can be done... but here is the things your going to need and DO..
complete 480 motor
complete wire harness
get a roller take off all motor mounts and strip frame for weld penetration
basically there you are... just make sure all sprockets line up... and make corrections accordingly
Adam
86 ATC 500R the duner..
85 ATC 500R...the not quite finished faster duner
1985 ATC 250R Bone stock!!
1985 ATC250R mx/duner
1986 TRX370R MX/Duner
94 Banshee 400PV Cheetah 105RWHP
