Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: Painting Plastics?
    Southeast Missouri
    23
    Question Painting Plastics?
    I need some advise on this Krylon Fusion paint. I have a 1983 YT 175 Tri-Moto that I am trying to fix up that I bought for a $100.00. It was sitting in a barn for about 10 years. I have tried sanding and painting but when i went to put my clear coat on it started to wrinkle in the places where the plastic commonly flexes. If anyone has any advise what I can do to restore the looks of this old yellow beater I would greatly appreciate it! The plastics are really in good shape for the most part but I want them to look a little closer to new if you catch my drift. I have seen some pics of a couple of yellow tri-motos on here that look really good, I wonder what they did? I CAN'T FIND THESE FENDERS NEW! PLEASE HELP!
    El Reno, OK
    92
    is the clear coat the Fusion paint as well?
    if it is it shouldnt wrinkle. if its not, dont use it. you could possibly use gloss yellow
    and that should look pretty good.
    my name is Cory, and ive become addicted to 3 wheelers.
    Yamaha 175
    need some tech help with it.
    crd00's Avatar
    crd00 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2006
    somewhere over the rainbow
    323
    You have to put a coat of primer for plastics on underneath the basecoat(before you spay the colour), then you spray on your clear coat so it wont rinkle and the paint will bend when your plastics bend. You have to use the same name clear as your paint or it wont go on right and your paint job will be runined
    WWW.FASTRACKZ.COM!! Totally dedicated to Atv's/MX/Sleds. Go take a look at the photoalbum and drop into the forum and say hello!
    Southeast Missouri
    23
    No it is 500 degree clear coat from wal-mart. I figured the higher temp stuff would work better since it might sit outside for now. I have a quad that gets first dibs on storage. I couldn't find any fusion clear and I think part of the problem might be the temp that it was out at the time. I don't have any place inside to do this work right now. The temp was prolly somewhere around 45-55 degrees with low humidity and the sun was out. The can says 50-80 degrees is optimal. Paint alone was looking great berore the clear though!
    Southeast Missouri
    23
    Primer? Even though the Fusion paint says it doesn't need one?
    crd00's Avatar
    Feb 2006
    323
    Ya it proably does say no primer but on metal you wouldnt have to but with plastics its better to use the primer for plastics, because if you dont your paint job wont turn out as good and it will rinkle as you said
    crd00's Avatar
    Feb 2006
    323
    I do it all the time with my fenders
    Southeast Missouri
    23
    Well crap, I guess i'll have to strip and sand it back down then. I never found any plastic primer. Any ideas where you can get it or who makes it?
    Thanks.
    Southeast Missouri
    23
    So it works good on your plastics? What kind of primer do you use? Is it made specifically for plastic?
    crd00's Avatar
    Feb 2006
    323
    it come in a spray bomb, autocolour makes it, you should be able to buy it at any autobody shop
    crd00's Avatar
    Feb 2006
    323
    yup its just for plastics, bodyshops use it on plastic bumpers on cars, plastic door mouldings etc. I use it all the time when I paint them
    Southeast Missouri
    23
    Thanks alot! I will try to find some and see what happens. If I ever get this thing done I will put up some pics but that might be awhile the stupid weather doesn't want to cooperate, lol.
    1. 2005 Yamaha Raptor 660R Special Edition
    2. 1981 Yamaha YT 125 Tri-Moto (Unbelievable shape) SOLD
    3. 1983 Yamaha YT 175 Tri-Moto (Under restoration)
    4. 1983 Honda ATC 200E Big Red (Under restoration) SCRAPPED ( too far gone)
    5. 2002 Ford F-150 XLT Supercrew 4x4
    6. 1997 Ford F-150 XL Sport 2x4
    7. 2005 Yamaha Grizzly 660F
    8. 1997 Yamaha Timberwolf 250 2x4
    YTM200BOY's Avatar
    YTM200BOY is offline All your base are belong to us???? Arm chair racerNew to the board
    Sep 2005
    Illinios
    37
    lol good luck man its snowing in march up here in illinios w.t.f is this all about lol.. Yeah man this summer im painting my ytm200EK hopefully it looks a bit odd with a 225dx black front fender lol i want to make mine bright yellow also. so hay if you can do me a favor when you do yours tell me what you use and tell me how it turns out k? well thanks man and good luck! -Joe
    Brandon, Manitoba
    2,209
    Dont waste your time with paint. Especially for yellow fenders. The best, easiest way to do it is to take a razer blade. Hold it perpindicular (90 degrees) to the plastic and scrap back and forth with a little pressure, it should take off a fine shaving of plastic. underneath, it looks brand new, the plastic will still be scratched, but its not bad, and since its yellow plastic, you can hardly see the scratches. If you are really worried about scratches, start wet sanding, from 600 to 2000 grit, then use rubbing compound and finally some kind of glaze or car wax. But I think with just scraping with the razer blade, you will be quite surprised what that brown coating of rotted plastic was hiding.
    Do no hold the razer blade at any other angle other than 90 degrees, you will gouge into the plastic and it looks like crap, I did it in a couple places on my fenders.
    Here are my fenders before and after, this is razer blading, then hours of wet sanding. Turned out PERFECT!!
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    yeah man looks nice i sanded and scrapped my rear fender and it looks beautiful also... but my front fender is black and i tried scrathing it and it looks really bad. Also i think i am going to throw out my gas tank cover because there are cracks on both sides. lol so yeah and my front light plastic is garbage also.
