Results 1 to 9 of 9
Thread: KLT 160 Help!!
    Aug 2005
    Botetourt,Va
    11
    KLT 160 Help!!
    I just picked up a 160 from a guy that had the carb off of it.I took the carb apart and cleaned it and adjusted it twice already.It will start right up and runs good but will idle wide open.It is running lean and if I put my finger over what I assume is the vent hole it will die.No matter how I turn the adjustments it doesn't change anything.Any ideas?
    1986 YAMAHA TRI-Z(X-RACER) 1980 ATC 110
    1985 ATC 110
    1983 ATC 200
    1986 Yamaha 225DR
    1983 Yamaha 200
    1985 Kawasaki KLT160A
    1982 Kawasaki KLT250A
    1992 Honda 250X Race ready
    2002 Yamaha Blaster Tricked and big bored!
    1999 E-ton Lightning 50cc
    1985 250ES Big Red
    1985 200E Big Red
    1984 ATC 200M
    1979 ATC 110
    1984 ATC 110
    1985 ATC 350X!!!!! IN PIECES
    1987 Kawasaki Mojave 250
    1992 Honda Fourtrax 300 Mud Wheeler!
    1998 Kawasaki KX125
    1982 Yamaha YZ250
    Dad's ride 2000 Argo 6x6 Bigfoot
    Randolph NY
    597
    Have you moved the needle in the carb at all or the idle screw?
    Aug 2005
    Botetourt,Va
    11
    Yeah they do not change anything.
    1985 ATC 110
    1983 ATC 200
    1986 Yamaha 225DR
    1983 Yamaha 200
    1985 250ES Big Red
    1985 200E Big Red
    1984 ATC 200M
    1979 ATC 110
    1984 ATC 110
    1998 Kawasaki KX125
    1982 Yamaha YZ250
    Des Moines, IA
    1,303
    This almost always means you don't have the carb slide in right. It's either backwards or just not seated properly. Take it out and make sure it goes down all the way.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Aug 2005
    Botetourt,Va
    11
    Thanks, I have done that several times and still no difference.
    1985 ATC 110
    1983 ATC 200
    1986 Yamaha 225DR
    1983 Yamaha 200
    1985 250ES Big Red
    1985 200E Big Red
    1984 ATC 200M
    1979 ATC 110
    1984 ATC 110
    1998 Kawasaki KX125
    1982 Yamaha YZ250
    Randolph NY
    597
    Must have a air leak somewhere, put oil or soapy water around your bearing seals, gaskets, and what not and look for bubles or the fluids being pulled in.
    Aug 2005
    Botetourt,Va
    11
    What is the other hole coming out of the carb?IS it a vent or should it be hooked to something?I am not familiar with the kawis much!
    1985 ATC 110
    1983 ATC 200
    1986 Yamaha 225DR
    1983 Yamaha 200
    1985 250ES Big Red
    1985 200E Big Red
    1984 ATC 200M
    1979 ATC 110
    1984 ATC 110
    1998 Kawasaki KX125
    1982 Yamaha YZ250
    Des Moines, IA
    1,303
    Plug that extra hole and see what happens. I had a vent or something on my KLT200 and the bike wouldn't idle down until I plugged it. I never did find out where it was supposed to have gone, but plugging that made it run, so I went with it.
    Aug 2005
    Botetourt,Va
    11
    I did and as said before it will idle down and then die.
    1985 ATC 110
    1983 ATC 200
    1986 Yamaha 225DR
    1983 Yamaha 200
    1985 250ES Big Red
    1985 200E Big Red
    1984 ATC 200M
    1979 ATC 110
    1984 ATC 110
    1998 Kawasaki KX125
    1982 Yamaha YZ250
