Ok so I've always seen trikes as higher on the food chain than quads and I'm working on this 350x and I needed a shift shaft.
And eye balling the 300ex you just swear that the lower engine is identical to the 350x, if not darn close. So I thought about it and decided, threw the EX on jack stands and ripped the side cover apart.
Now there's probably someone on this board that already knows this but they didn't reply to my thread so I'll claim it as new info untill informed otherwise.
THe 300ex and 350x shift shafts are INTERCHANGABLE!
Discontinued huh honda? Haha, I think not!
The only difference I can find is that the snap ring is a little farther out on the shaft, big woppdee doo! I have a shift shaft for my 350! and not only that but after more examination, the chain cover, and many other parts are interchangable. I'd even wager that if you swap the ignition systems you could bolt the electric starter cover up to the 350x engine cases. Might need some slight modification but not a whole lot of work. I doubt the EX electrics would be enough power for the 350 though but who knows.
As I said someone may have already known this but I couldn't find it by searching the board and no responce to my previous thread, so now, anyone needing a shift shaft for thier X, order up a plentiful EX one!
