Hay guys is it possible to have a sticking or sticky valve.![]()
Yes. I'm not sure exactly how to fix it, but yes it is possible. (Only in a 4 stroke though..)
'85 250SX - My first ever trike and my pride and joy
**Check Out The Whole SX Project Here!!**
'85 350X - 10:1 Piston, performance cam, '86 engline/carb
'85 Powervalved Tri-Z - Fully modded - Soon to have a Corey Sprock 310 kit
'85 250R - Began the modification process. This bike is going to scream! -295cc kit, Ported, Drag intake, 40mil Keihin, VForce reeds, shaved head, PT High Rev pipe, Fat Boy 2 Silencer, +4 Durablue axle, +2 swinger-
What's yer problem that you're having? More likely that you'd have a bent valve, in which case the head has to come off and the valve needs to be replaced. Bent valves are caused by overrevving or incorrect cam timing/timing chain skip.
[FONT="Palatino Linotype"]~My Rides (to name a few) ~
1986 ATC250R, 1985 ATC350X
1985 ATC250R Missile (90% done)
1983 ATC185S
1999 TRX416EX
2003 Honda CBR600RR
1990 Yamaha Zuma
1985 XR80 w/100 motor
1967 Honda CB77, '65 CL77
1962 Puch 250 SGS
1984 XR350R (owned since I was a kid)
1972 Suzuki T350 Rebel, '73 T500 Titan
1964 BSA A65 (needs restored)
1968 BMW R60/2 mint original bike
1976 Kawasaki KH500 triple
Anybody have parts to trade for the above models?
You say you had no compression, that could because one of your valves is stuck open. (check through the 50 pages of threads) I guarentee you sticky valve was metioned.
yeah thanks guys you made my day knowing its fixable but then again whatever it is is fixable only money will stop me!! haha My mom is giving me crap about selling it becuase its a waste of garage space and all this crap... i said give me a year then well talk about it... lol ill get her i have faith!
you have 500 posts saying the same thing over and over again hahaah
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
also anyone got a front headlight plastic its all i need now mine is cracked and looks bad.....
So ----if it looked good, Mom wouldnt give you grief about keepin it????
Get it runnin first----before spending cash on "UNNECESSARY-AREAS"
well its almost done it looks pretty good! ill have to get *Edited* some updated pics. I recently cleaned the plastics redid the exhaust pipe and made it silver again aswell and the heat plate on the side.. Also i put a new foam pad on the front hadlebars and added some killer decals.. Looking awsome i cant believe its mine now it just needs to start.... I also sanded some parts down.. ill get some pics tomarrow guys in a different thread topic. later - Joe
Who is going to be pulling the head, if the valve is the problem?
I would suggest having a mechanic do it.
YTM heads are hard to work on, the rocker arm shafts get stuck in really good and they're impossible to get out how the manual says.
I took mine to a cylinder head shop, they pulled the rocker shafts, replaced the valve seals and grinded the valve seats.
Cost me $100 for the head work, they had to make a tool to be able to pull those shafts out. I think a head gasket is $27 or so.
yeah most likely if that is my problem are family freind will do it he is very smart and has alot of skills with motors. It will be a ckae slice for him..
