Results 1 to 8 of 8
Thread: ATC250R swing arm Part numbers
    Anaheim
    1,270
    so... iam trying to order swing arm bearings and dust caps and all that... well i cross refrerence some numbers.... and iam confused... when i went to order them by part number they said it was TRX250R 85-87..... so is this right? by the way the bearings are pivot works... i need to know by tonight tho... as i need to have them here no later then friday.... cause stuff;s going to get very bussy... very fast....THANKS .... please get back
    Adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Pennsylvannia
    1,147
    My guess is that the part number is right. Most of the early 250R TRX stuff interchanges with the 250R ATC stuff.
    Dads is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    Richmond, NH
    219
    trx bearing 20x26x30 ------83/86 250r 22x29x24
    trx cap 15x35x6 & seal 27x33x5------83/86 250r 15x32x5
    trx collar 20x26x13 ------83/86250r 29x35x32
    trx pin 15x20x64 ------83/86 250r 15x22x83
    Did you try www.pivotworks.com,
    Anaheim
    1,270
    yah i watned the pivot KIT the whole dang thing... you said you could only get teh bearing..
    Adam
    May 2005
    Australia
    1,047
    I ordered that Pivot Works kit(TRX250R 85-87) and it all fitted my 85 250r swinger when i rebuilt it.
    Aussie
    Keeping 3 Wheelers Alive Downunder !
    Dec 2002
    Richmond, NH
    219
    If the 86/87 TRX250r fit the ATC250r, I can get that kit for $36.41+ shipping
    Dec 2002
    Richmond, NH
    219
    I just checked and the 81/82 250r take the same bearing as the 86/87TRX
    Cincinnati, OH
    3,289
    check in the classified there is a guy there selling the bushings kit that replaces all the metal parts and they WONT RUST!
