Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: What other hubs fit 86-87 tecate axle?
    Dec 2003
    australia
    838
    I would'nt recommend running 18" tyres on 10" rims on the trail, but 20" tyres on 10" rims shouldn't be an issue.
    My Aluminium douglas 9" rims on my quad get bends/dents in them all the time but my standard 10" rims on my Tecate have yet to have any problems.
    I would have no problems recommending running standard 10" tecate rims with 20" tyres for trail riding.
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
    Newfoundland
    5,280
    BUMP for a usefull thread.
    Wish I hadn't sold the 4/4 86/87 Tecate hubs I had. Wondering if anyone has tried or can try 300EX hubs on their second gen Tecate.
    300ex hubs are wider then 200X hubs right? Are 86/87 200X hubs the same as 300ex hubs?
    James
    Las Vegas, NV.
    2,527
    Quote Originally Posted by OZQUAD44
    That's because the standard rims on the 86-87 Tecates had that rolled lip and are the strongest wheels that I've ever seen. I used to break rocks with those wheels when I was running 18" Fast Trekkers on them on my 250R, and they rarely got more than a scuff on 'em.
    Apr 2009
    Davis County, UTah
    Reading between the lines and not very well
    So.... I picked up a 1980 ATC 110 yesterday for $80 with three bad tires, a missing seat, and doesnt run. ?Bad deal? anyways, I took it home, put a new plug in and it fired right up. It blows tons of blue smoke though so I think I will be rebuilding the top end. Anywho, my big question is are the hubs from the 83-86 or what not ATC 110's that are 4 lug the same spline count as the ones on my 80? If I could get 4 lug hubs, then I could pick up a set of 4 used tires and rims off a quad for around a hundred bucks instead of one tire for 85$. Hubs are 20$ shipped online, so are they the same spline count?
    According to the discussion above, sounds like most anything ATC is the same.
    Sorry, Im a noob, this is my first ATV. Not trying to waste your time, please help me out.
    Or if you could reffer me to a cheap place for tires.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by sawyersneverlie View Post
    Yes, the hubs should work just fine. If you change to 4 bolt hubs all the way around you will need to find a different hub for the front as well. I have hubs available if you need hubs ( front and rear ).
    Howdy
    Dec 2003
    australia
    838
    I just fitted TRX450R extended billet hubs to my 87 T3. You need to make a 7mm spacer to make it work. But once on there they are a work of art and completely negate the need to try and find those elusive Tecate wide axles.
    ForeverThreeWhe's Avatar
    ForeverThreeWhe is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2009
    Australia
    356
    Quote Originally Posted by OZQUAD44 View Post
    Kawasaki.....add a little Honda to it and it'll work!
    Mar 2005
    overton, PA
    5,257
    i'll check my 300ex out tomarrow with the kx500 tecate project i want to make my t-3 a lil wider its just too un controlable with the 500 powe rin it now.
    Dec 2003
    australia
    838
    Quote Originally Posted by ForeverThreeWhe View Post
    no problems at all with that, just as long as I don't add too much Honda. I don't want to start slowing the thing down now do I.......
    Mar 2009
    Elma, NY
    11
    I scored a nice set of 430mmx9" ohtsus w/ steel rims for under $100 bucks off eVil-baY. Can't what to try on 86r clone f/t racer. they also had dual pattern
