Results 1 to 12 of 12
Thread: help
    buffalo ny
    7
    help
    im working on a 3 wheeler i beleive a honda 200s or es or x im not sure its red . but i rebuilt the topend for my friend and put it all back together and it wont start not even a pop its getting gas as the plugs wet its got compreesion but the spark seems kinda weak im not sure wat it could be. how do *Edited* adjust the timing on it? it has the cdi towards the top of the motor any help is appreciated
    buffalo ny
    7
    bump c,mon someone help lol i want to mess with it one more time *Edited**Edited* i go to bed but want to know wat to do
    buffalo ny
    7
    ok i found out its a 200m because it has the elec start and recoil backup but anyway does anyone have any ideas on why its not starting
    buffalo ny
    7
    bump someone help it now has spark and gas why wont it start? could it be the valves?
    Jan 2005
    Tennessee
    850
    I had what sounds like the same issue. I took the CDI cover off and put flipped the flywheel like think inside over. That was my problem. It would spark sometimes, and sometimes it would not. You may check that. This was on a 200x though, should be about the same. Hope this makes some since.
    buffalo ny
    7
    so flip it over?
    Jan 2005
    Tennessee
    850
    Its hard to describe. Don't turn it around backwards it wont fit. Slide the flywheel off the camshaft just barely, then turn the flywheel one half turn and slide it back on. Hope this make since.
    buffalo ny
    7
    Randolph NY
    597
    Helpfull pic
    Randolph NY
    597
    A few more...
    Jan 2005
    Tennessee
    850
    That was my issue when I did some top end work. My retarded seld put it on the wrong way.
    buffalo ny
    7
    k i got spark but i found out theres not enough compression i noticed thers only like half a gasket on the top part of the heat by the cam also i put silicone on it but when i tighten it its too hard to pull the starter
