didnt know what kind of fluid is suppposed to be used..... also the level indicator is the short 10mm bolt about halfway up the case? thanks guys
10W-30 oil is what I use.
Yes, the indicater is the 10mm bolt.
thank you very much.... thats what i have always used but it was filled with atf .........
so i had to make sure
i have 10w30 in my tri-z , but run atf in my shee
