I recently picked up an 85 200x. the front brakes worked when I got it, but they were sticking and dragging real bad. I pulled the caliper, unseized the floating pins, and cleaned out the caliper and piston. Both the floating pins and the piston moved freely by hand after assembly. I reinstalled the caliper and now I can't get it to bleed for anything. I bled the master cylender by hand and I'm getting awesome pressure, but when I try the bleeder on the caliper it just trickles out. I checked the bleeder and passage and it's clear, I checked the brake pads and they are new. What the heck is wrong?? I had pressure before what happened that I'm not getting pressure now??
