Results 1 to 15 of 19
Thread: straightening an axle ??
    HypnotizeMindz's Avatar
    HypnotizeMindz is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami, Fl
    344
    i have an axle for my 86 200x
    one side is slightly bent
    has about 1/2 inch wobble.. or bend
    what can i do to straighten it ??
    is there any place i can send it to and have it straightened ?
    Aug 2002
    NY
    2,652
    i had my banshee axle straighten at a local Brake shop. cost $15 bucks any place with a good lathe could probable straighten it good luck
    Miami, Fl
    344
    axle
    thanks man.. i'll know a machine shop with a lathe... but i didnt know they could straighten an axle
    i dont know when i'd be able to take it....
    i work from 5:30 am to 5:30 pm.... and the place closes at 4:30
    i'm not complaining about my hours though... Big money
    me = heavy machinery operator
    Aug 2002
    NY
    2,652
    no prob they need a press too i think i wasnt there when he straighten the axle just ask qwuik and split because i was happy it is straight now good luck
    Nov 2002
    132
    It's not that hard to do. Inspect it by rolling it on a flat surface, a surface plate works good if you have one. You can use a glass plate if you don’t have a surface plate. When you see the bend, mark it with stick chalk or use a marker. Now place the axle on a 2x4 with the bend up. Pound on it with a brass , if you don' t have a brass place a peace of wood on the top and then pound on it with a steel .
    Pound and inspect, pound and inspect until you get it a straight.
    Ashland City, TN
    2,576
    Or you can take an OxCetylene torch and heat it up, and carefully bend it back to shape. Be careful not to turn the metal to liquid, just heat it up.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Nov 2001
    B.C.
    933
    If you want to screw it royally, use heat...
    Heat removes the temper.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Re:
    Take it to a machining shop and have it done right with a press. Like Mobular said, heat should be a no no
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    If it bent once, it will bend again. Unless you have it strightened and retempered. Spending money having it strightened just delays replacing it or fixing it right
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Miami, Fl
    344
    axle
    yeah.. thanks for all your help.... my brother's going to take it monday morning while i'm at work
    Heat weakens metal, not a good idea. I was able to straighten forks which bent so bad the tire touched the frame. 2 v blocks which you roll the axle in and then a dial indicator to find the high spot. Then we just used a press and had to go past the bend and beyond straight to get it straight. Still using them today. Usually guys don't want to bend or whack stuff in a lathe chuck because they aren't made for that.
    Miami, Fl
    344
    straightening
    i dont really like to bend things back to original.. but i dont want to spend alot, or junk my axle
    it's jus a small wobble... they should be able to fix it
    Dec 2002
    42
    couldn't you use heat to straighten it then get some kysenite (hardener) to harden it
    85 250R
    Howdy's Avatar
    Celina, Ohio
    10,079
    You can but it will never be as good as if you didn't heat it at all. Heat and axles can be a bad combo.
    Miami, Fl
    344
    axle
    yeah.. i had an axle straightened with heat on my last 200x...
    it bent again the next day...
    that's why i asked on here who and what could straighten it... i didnt want heat to be a choice...
