Thread: a few 84 250r questions.
    Jan 2005
    Jones, Michigan
    1,821
    Well i just got a project and i'm anxious to get it done so i want to order some parts ASAP. it is bored out like .40 or .60 over but needs bored out again because the piston seized up in it. It appears to have some port work done to it, it has a dg head and it also has an answer silencer. i might get a 300 kit for it eventually but i'm not sure.
    What carb would be best? stock 84 r carb or is there somnething bigger/ better?
    What are some good reeds to get for it?
    wheres the cheapest and best place to get a piston and rings for it? what brand of piston? I was planning on wiseco.
    whats the best tires for an r? I ride in dirt, grass, mud, and probablly the mx's at TF06.
    anyone who has a carb, a bolt on and go top end, a complete cheap running engine, 300r kit, hoosier style tires, or any other parts can PM me and i might be willing to buy. I need to get this beast done for TF06.
    Kevin
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Mar 2004
    North Central Ohio!!
    2,712
    It's been my experience that these air-cooled top-ends are prone to seizing. Make sure after you get it back together to run your first tank of fuel at 20/1 and take it easy on it for the first hour or so.
    The other thing I've found out about air cooled R's is that you might as well figure on resleeving your cylinder. IF you can find another one, it's almost garunteed it will be, or need to be bored to the max already.
    Don't drag your feet and miss TrikeFest. Send your cylinder right to Wiseco, in Ohio. They will put a new sleeve in it for around $125. Then they will fit the piston kit correctly to the sleeve. When you get it back you'll know it's tip-top. Looking at around $350 for everything.
    Jan 2005
    Jones, Michigan
    1,821
    Quote Originally Posted by Derrick Adams
    i do have another parts engine. I have the jug, head, and most of the bottom end. the other jug i have had rust in it (someone left the sparkplug out and it was outside) so it will need a bore also. I tried to hone it but it's too bad.
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    Jul 2003
    Cheyenne, WY
    56
    Pipe
    I've got a bassani pipe thats pretty descent......just let me know......
    83 Honda 250R (when it runs like its supposed to)
    85 Honda 350X - Just picked up 9JUL06. Needs alota work.
