Results 1 to 15 of 17
Thread: could this be it??
    YTM200BOY's Avatar
    YTM200BOY is offline All your base are belong to us???? Arm chair racerNew to the board
    Sep 2005
    Illinios
    37
    Question could this be it??
    Ok guys you all know my trike hasnt ran since last year some time.... Today i was told that if *Edited* crimp the overflow for the carb it wont start could this be the anwser im lookin for to start this baby up??
    Pennsylvannia
    1,147
    I assume you mean the overflow hose? Go see if your overflow is crimped. If its not, thats not the answer. If it is, cut it off and see if it iwll start..
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    no inside my carb the metal piece leading to the overflow hose is crimped.
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    could this be why it doesnt start???
    Pennsylvannia
    1,147
    It could be. Maybe a vaccum or something. Try uncrimping/fixing it and see if it works. Thats the only way to find out.
    Feb 2006
    north of buffalo
    557
    do you mean the wire that holds the hose to the bottom of the carb?
    Runners:
    84 200s
    05 rancher
    12 rancher
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    no lets get something stright guys... my carb doesnt have a overflow hose of a clamp its basically cut off inside the carb because my dad crimped the metal line that is used to drain the carb on the bottom get it???
    May 2005
    Dorset United Kingdom
    1,408
    Take a picture......
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Cody's Avatar
    Cody is offline Just Too Addicted Arm chair racerJust too addicted
    Feb 2005
    FLORIDA
    731
    Yea, why did he do that? I think it will run now.
    1985 Yamaha 200E Shaft - New Toy / Project
    1983 Yamaha YT175 - Kinda retired?
    Brandon, Manitoba
    2,209
    I know what your talking about...if you take the bowl off, there is a metal tube that sticks up from the bottom of the bowl...actually, now that i think of it, it should be built right into the side of the bowl, mine is...take a picture.
    do you know how to drain the oil? I Bet its right full of gas.
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    well guys my dad isnt home so i broke the top of the metal tube off "the part thats crimped" its shorter now. But that wont efftect it will it? so i hooked the gas line back up and it started leaking outta the overflow... its open now but leaks. how do i get the thing from stop leaking??? its got a new seal, needle valve, and valve seat....... wat gives? do i have to adjust the floats up or down anybody now?? well thanks -Joe
    Oct 2005
    Pennsylvania
    863
    Unless the drain screw is open --that steel nipples is blocked off anyway---Sorry , thats not it.
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Oct 2005
    Pennsylvania
    863
    Overflow--???? Or, Vent Tube?
    Brandon, Manitoba
    2,209
    Your needle and seat must be worn. Take the bowl off, keep the fuel line hooked up and push up all the way on the float. turn the gas on. If any gas drips out, the needle and seat is worn. Just keep the fuel shut off when your not riding.
    Did you drain your oil?
    central kansas
    27
    That tube is the overflow that drains excess fuel from the carb if the needle/seat leaks. It does bypass the drain screw and allows fuel to exit from the same drain. The screw just opens up that passage to the bottom of the bowl, the tube is open to the top. It will drain out fuel if it is now shorter than the set float level. So even if the needle/seat IS shutting of, the fuel will still run over and drain out that tube if it is too short.
