Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: could this be it??
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    if there is any fuel in the bowl it should start,,, turn the gas on till the bowl is full then shut it off and see if it will fire up,,,,, if not you have other problems,,,,,,,,,,,,
    Jan 2005
    RI
    2,530
    so basically...if the tank has a lot of gas in it, and the overflow tube was blocked off completely, and your float was leaking...you basically flooded your engine. The weight of the gas in the tank will push it through the hose, and since it wont go out the overflow, itll go into the motor right? This will have your motor flooded 24/7....you need to shut the tank off, pull the plug, keep on kicking it over, maybe take the pipe off, blow it out with compressed air until its clear, then ill bet that your bike will start.
    Good luck
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
