Thread: how do you remove the front hubs/rotors on a 93 f150 4x4?
    Jan 2005
    Jones, Michigan
    1,821
    Well i need to change the rotors on the front of my 93 f150 4x4. I just cant get the hubs off. I went and bought some special socket your supposed to use but all im doing is stripping out the little notches where the socket slides into. This this is pissing me off more than anyone knows. any info would be great. According to the manual i think it has a dana 44 front end, but then again this manual hasnt helped me one bit.
    Kevin
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Jan 2005
    massachusetts
    42
    umm
    is it a star pattern bolt on the hubs?
    if so i would say soak them in wd40 and to save on stripping them, take the tool if its a star pattern socket put it on an extension and give a few blows with a regular claw and then try that.
    hope this helps
    ryan
    Oct 2005
    Pennsylvania
    863
    somewhere on that big nut is a small metal "WEDGE" that stops the nut from backing out. It has to be removed . There also a series of circlips that lock everything in the tubes. "Muscle-ing" the nut wont help if the "SAFETY " devices are still in place.
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Minnesota
    790
    You do need to buy a specific hub socket (I'm assuming you already did this) If you asked for one to fit a D44 for your truck you should have the right one. You probably have a Dana TTB 44. You have to use this hub socket to remove the two nuts that hold on the rotor assembly. After that I believe the whole assembly just slides off. I would highly reccomend constantly soaking the nuts with a penetrating fluid, like liquid wrench for a while. I snapped a breaker bar using an extension to try to get the hub nuts off my old jeep. Ended up buying a cheap impact wrench and it worked well, If you don't own one I would try borrowing one if you can... Ugg i gotta do the balljoints on my '89 with the same setup soon, then I can feel your pain again...
    Goodluck
    -86 Polaris Scrambler 250r/es - sold
    -84 200es Big Red
    -92 Ski-Doo Formula Plus 583 -88 Safari 377 -68 Super Olimpique 299
    -87 Jeep XJ 5" lift/many other mods-sold
    -89 F-150 4" Lift/33s
    -90 Acura Integra - '83 Mustang 5.0 convertible (the new project)
    Ask me about custom cut decals!
    Eastern Long Island
    1,688
    Ford used 2 different styles of spindle nuts . One is a standard Dana 44 socket with the 4 teeth and the other is a special spring loaded locking nut that needs a different socket. I ran into this when I was doing the front ends in 2 93 Broncos and they were different.
    Lots O Trikes!!!!!
    Nov 2004
    Atlanta TX 3-states area
    1,592
    Its not reverse thread is it?
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    2003 Polaris Sportsman 500
    There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
