Thread: Where is the oil filter on a 200s?
    Aug 2005
    Wake Forest, NC
    50
    where is the oil filter on a 200s? Does it have one?
    Jan 2005
    Tennessee
    850
    There is a bolt cover on the bottom that looks the same as the valve covers. On the left side remove it and its behind there I believe.
    Dec 2005
    Tulare California
    10
    200s
    The oil drain plug is on the left side of the bike when you are siting on it. It is just under the shifter lever. There is a spring and wire filter behind the cap.
    Honda 350x sold
    Honda 200x sold
    Honda 250r sold
    1985 Honda 250r
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    It's not really a filter, it's a screen that you clean and re-use. Looks like a thimble made of wire mesh.
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    NE Arkansas
    2,344
    yeah, that's it. Hmm, that remiinds me, time for a oil change, hehe.
    actually there is another oil filter, you have to remove the right crankcase cover, it's the oil filter rotor. I have never changed/cleaned it on mine, and it's rarely ever mentioned here, so I don't worry bout it. The manual calls for the inside of the oil filter rotor cover and rotor to be cleaned and a new gasket used. I've never even seen this gasket listed when searching for parts. Again, I don't worry bout it, maybe someone else has some input.
    Later
    Travis
    My Rags
    Brandon, Manitoba
    2,209
    Yea, on my 200s the oil rotor filter has never been cleaned. the only bolt ever taken out of that motor is the drain plug. I think the carbs been cleaned less than 5 times in its whole existance too.
    Aug 2005
    Wake Forest, NC
    50
    Thank yuo everyone! Time to check it out..
