Results 1 to 7 of 7
Thread: z questions!!! again
    gardnerville,nv
    33
    okay so i swapped the right fuel pump onto my 85 tri-z. it has been rebuilt now, all new lines(vacuum, and fuel) but still on a pull from a stop around third it acts like its running out of fuel. i have pulled the carb, cleaned it, checked float level, etc... im at 5000 foot elevation, have a 480 main jet, stage 1 yamawrench work done, and the plug reads nice......... also i installed a thermostat into my z where it was missing , however the t-stat has been discontinued thru yamaha, so i used a t-stat from the auto parts store that has a 180* temp. is this too hot ? the light doesnt come on however when i shut it off after riding it always pukes some coolant out..
    thanks in advance
    will
    denn is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Lehighton PA
    213
    hey, from ny own experience on a Z when you are puking coolant out the overflow it is usually the head that is warped. The head gets warped and allows compression to get into the coolant system. Which would allow coolant to blow out the overflow tube. Hope this helps.
    Denn
    gardnerville,nv
    33
    the head was just resurfaced when the engine was rebuilt less than three hours ago.... but i stilkl need help with this stuff!
    gardnerville,nv
    33
    nobody knows if the thremostat temperature is too hot?
    It might be a little It should open from 145.4 to 152.6 degrees F. according to the manual.
    Watertown, New York 13601
    3,382
    Run it with no thermostat, i am with no problems.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    gardnerville,nv
    33
    perfect thanks guys !!! now just to solve the starvation problem!!!
